991 Internals?
Old Apr 21, 2016 | 06:49 PM
918 Spyder's Avatar
918 Spyder has a reputation beyond repute918 Spyder has a reputation beyond repute918 Spyder has a reputation beyond repute918 Spyder has a reputation beyond repute918 Spyder has a reputation beyond repute918 Spyder has a reputation beyond repute918 Spyder has a reputation beyond repute918 Spyder has a reputation beyond repute918 Spyder has a reputation beyond repute918 Spyder has a reputation beyond repute918 Spyder has a reputation beyond repute
Originally Posted by Kinetic
I read the AMS review, part 1. The rods look very good. Is there anything on the pistons and other parts out there?
The pistons etc are all strong. You won't find anything stronger (barely) then what Porsche has in it. I even ran it with a 150 shot and now going 200. No issues at 150....
Old Apr 21, 2016 | 07:04 PM
Kinetic's Avatar
Kinetic has a reputation beyond reputeKinetic has a reputation beyond reputeKinetic has a reputation beyond reputeKinetic has a reputation beyond reputeKinetic has a reputation beyond reputeKinetic has a reputation beyond reputeKinetic has a reputation beyond reputeKinetic has a reputation beyond reputeKinetic has a reputation beyond reputeKinetic has a reputation beyond reputeKinetic has a reputation beyond repute
That's very impressive for factory internals!
Old Apr 21, 2016 | 10:06 PM
Markblackwell's Avatar
Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !
Jeff are you leaving the integrals alone on your build?
Old Apr 22, 2016 | 01:32 AM
918 Spyder's Avatar
Mark, I'm not touching the internals at all. Wish I would have the car back by VA but it won't happen.
Jeff
Old Apr 22, 2016 | 02:50 PM
sdg1871's Avatar
sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !
My understanding is that as power increases, you hit the car's fueling limit first, then the PDK limit and then at a significantly higher point the engine limit
Old Apr 22, 2016 | 02:56 PM
COBB Tuning's Avatar
COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !
Taken from the Porsche Tech Doc:
Similar to the previous model, forged aluminum pistons are used to reliably achieve
the high power values of the new engine. Many details of the piston rings were
improved to minimize frictional losses and a DLC coating was also applied to the
first ring. To reduce lateral forces and ensure reliable transmission of the enormous
gas forces from the piston to the crankshaft, the connecting rod was modified compared
with the previous model.
A computer-optimized design of piston and connecting rod in combination with a
short compression height permits the components to be designed with an optimum
power-to-weight ratio. The low mass forces bring about a reduction in the crank
drive loads and enhance the smooth running of the engine.
To ensure the load capacity of the new 911 Turbo engines as well as the higher
power and torque values, the pistons were strengthened and adapted. This made it
possible to increase the maximum peak pressures by more than 10% and considerably
improve internal efficiency. As a result, it was also possible to achieve the
increases in power compared with the previous models at comparable boost pressures
using new thermodynamic tuning (e.g. valve timing and timing angle)
Old Apr 22, 2016 | 04:11 PM
Stage7's Avatar
Stage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond repute
Is that recent for the 991.2? Or was that published for the 991.1 or 997.2?
Old Apr 22, 2016 | 06:05 PM
991.1 Turbo
Mitch
Old Apr 26, 2016 | 04:14 AM
KA 997TT's Avatar
KA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond repute
Great information. Much needed. This re-assures me for the long haul. I am intending to keep mine for a while, though stock for now, it gives me great confidence that by the time I feel the need for something "more" I can start modifying it, smartly, and keep it even longer.
stevepow
Jun 21, 2019 04:22 PM
tommyboy214
May 25, 2016 11:41 AM
xmaciek82x
Apr 6, 2016 10:01 AM
AriS4
Mar 22, 2016 03:04 PM
