Tire recommendations for Stage 4 & beyond
Old Feb 8, 2017 | 01:25 PM
wrs's Avatar
wrs
wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !wrs Is a GOD !
Originally Posted by gmd2003
10.49 @ 130.6mph witha 1.58 60 ft.
G
SO here is an interesting comparison. The left graph is with a new set of PZeros back when the car only had 4k miles on it. They were the original tires except the right rear was completely new since it was replaced under tire warranty a week after I got the car. This was the first run I made with the FVD piggyback and I cut a 1.59 60ft on the county road at 75F. The second graph is two years later with a set of PZeros that have two track events on them and about 6k miles or so. The temp is 81F and so I should get good grip but the car spun like crazy and I got a 1.72 60ft. Still the ET is better than with the piggyback and the tires are probably pretty hard due to the vulcanization but the 60-130 was 7.48s compared to 8.09s with the piggyback and the trap was 131.37 vs. 129.45. After the initial traction advantage the power of Stage 4 shows up but it still potentially has traction issues which could be the reason the rev limiter is coming on. The Porsche tech thinks that is possible, Carlos does too. I am waiting to be convinced, hopefully the car is available tomorrow and I can get out to the CR in some 60 degree weather which is ideal.
Assuming this is traction, I should see 10.3 @ 134-5 on pump gas.
Old Feb 8, 2017 | 02:47 PM
Nanook's Avatar
Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !
I forgot G what did your car do in the 1/4 bone stock again? Stage7 also did 132 and 10.29 with your set up![/QUOTE]
You talkin to me ?
Old Feb 8, 2017 | 03:36 PM
shifter_'s Avatar
shifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond repute
Originally Posted by blkonblk88
What's the issue with running R888's on the front as well...?
They don't make them in the size.
Old Feb 8, 2017 | 03:50 PM
SamboTT@ByDesign's Avatar
Hey buddy, no the other G. Awesome!
Old Feb 8, 2017 | 05:51 PM
gmd2003's Avatar
gmd2003 has a brilliant futuregmd2003 has a brilliant futuregmd2003 has a brilliant futuregmd2003 has a brilliant futuregmd2003 has a brilliant futuregmd2003 has a brilliant futuregmd2003 has a brilliant futuregmd2003 has a brilliant futuregmd2003 has a brilliant futuregmd2003 has a brilliant futuregmd2003 has a brilliant future
Here is my run from this weekend with 50 degree weather which was a bit over a -1000 DA . Amazingly despite the cool temps it hooked extremely well with the N1 Pzero 35 front/ 41 rear hot pressure. With a good DA I would think high 130's on 93 octane for your stage 4 setup.
G
Old Feb 8, 2017 | 08:58 PM
longboarder's Avatar
+1 to this . I have yet to have a 60ft time that was > 1.6 even on a non prepped surface, in fact just did a 1.52 60ft this weekend when it was 50 degrees out for a 10.28 @ 132.6mph( try launching on an r888 when 50 degrees , see ya!). Having used R888's as a track tire on my Z4M their grip while high intially goes off considerably very quickly with heat cycles and are horrible when temps are below 60 degrees or in any rain. Not really a good option for daily driving period IMHO. N1 Pzeros are hard to beat for a street tire >>>>>>> than PSS and comparable compound grip wise to a Sport cup 2.
George
A couple weeks ago I did a 6.04 second 60-130mph in the rain 50 degrees F on my bolt on 997.2 with r888's on all 4 corners. Vbox verified and posted on the 997 forum. I also have video right after the run showing the rainy conditions.
The r888 is used as a track rain tire for many and from my testing works great at the track in both cold wet conditions and on a 105 degree summer day and everything in between. Sure a slick will give you a better time but nothing is as versatile as the r888.
Old Feb 8, 2017 | 10:55 PM
blkonblk88's Avatar
blkonblk88 is infamous around these parts
Haha thank you! I wasn't sure if we were talking about the same R888's. I've been running them for years. Rain or shine. Up to 1900whp and seem to do just fine. And last time I checked they made them in 20's..?
Old Feb 9, 2017 | 07:22 AM
sdg1871's Avatar
sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !
Yes they fit as rear tires but unfortunately none of their 20 inch sizes work on our fronts as they're too wide
Old Feb 9, 2017 | 08:17 PM
gmd2003's Avatar
I'm speaking of the newer r888r as a road course tire , it's not my favorite because it heat cycled out very quickly (3rd day), and WAS horrible in the rain on track . It's a more aggressive tread design than the older r888 but that one was bad in standing water too . In my low tq Z4M after the 4th day the R888's are pretty useless on the street, in these winter temps . They fell off their peak grip by a huge margin on track as well. The sport cup 2 is a much faster tire on track in the wet , hell a pss is in the wet . When new on a dry track once up to temp the r888 had great grip. I just feel it's a poor compromise as a street tire , not that you can't get away with it , you can't put enough heat in it on the street especially when it's cold out . We are talking very different purposes though and I haven't used them on an awd car . That being said I'd love to see you launch any car in sparse standing water at 50 degrees with a moderately used r comp lol .
Old Feb 18, 2017 | 11:53 AM
wrs's Avatar
wrs
1.55s 60ft 0-60 2.75s and 2.43 with 1ft rollout, 1/4 mile 10.40 @ 131 on 93 pump gas
Since this is about tires, here is what I did with the new PZero N1 on stage 4 hardware but Stage 3 map on a county road. I had a modified Stage 4 map that didn't pan out but I am putting the stock stage 4 map back on now. I will report when I get those results.
