Porsche 991 Carrera Product Development by Agency Power
Old Jun 12, 2012 | 07:15 PM
vividracing's Avatar
The new Porsche 991 is more then just a body change for the 911 series. Leaked out over a year ago, the 991 by Porsche was to completely change the way the 911 would be driven and open up a future to its progressiveness. Over the years, and including my ownership of a 996 Carrera, 996 Turbo, 997.1 Turbo, and now 997.2 Turbo S, we have seen each model slightly get more and more refined. The 991 wheelbase has increased 100mm over the outgoing 997 model. As well, its overall length has also increased by 70mm. A new transaxel was developed so that the rear wheels could be moved 76mm backward in relation to the position of the engine. This significantly improved the weight distribution and cornering performance of the new 911.
Vivid Racing was able to get its hands on a 2013 Porsche 991 Carrera S to do product development with sister company, Agency Power. The white color and beige interior are a nice combo with the 7 speed PDK transmission. Instantly noticed is the rear end with the sleeker looking taillights and the decklid. Curousity had me popping the decklid right away only to find a small 30 by 8 inch space with 2 fans and a logo. (On a side note, for those that are wondering where the intake is or how to change the air filters, you can see our complete dissassembly of the rear end on the Project 991 Carrera Gallery Here.) This should be fun I thought! The front end has some more curves and the 997 lights are slightly carried over. But the big in your face change is the inside. The mini me center console of the Panamera is a big change. Buttons are everywhere. Having a PDK on my Turbo S, I was used to that and the function. Turn the key on, the dash takes on all sorts of new LCD displays. After learning where the newly positioned buttons were, we headed to the lift.
Like many OEM’s taking cue from the aftermarket, the stock exhaust is fitted with almost a valvetronic type setup which opens a flapper valve on the center muffler when the sport button is pressed. However for the Porsche enthusiast, the vehicle is still lacking a true sports car noise. Agency Power set out to build a modular exhaust system that would allow fitment for many different types of 991 drivers. The exhaust is broken down into 3 parts: The headers, the secondary mufflers, and the main center muffler.
The first part we built were the Secondary Muffler Bypass Pipes. These simple U/J pipes remove the mufflers that are tucked up in the rear quarter panels. Why the reason for these I do not know. Typically in the past we either see a main center muffler or 2 mufflers with catpipes. So this was the first simplest part to change out. Keeping the same diameter for a perfect OEM replacement, these pipes are straight through which not only eliminates any muffler packing or baffling, but also the weight. Each stock muffler weighs approximately 15.6lbs. The Agency Power Muffler Bypass Pipes are about 3lbs each. Now eliminating restriction, we have also saved about 25lbs off the rear end. Because this part still retained the factory headers with cats and the factory center muffler, it added a slightly deeper tone to the exhaust but not a drastic droning change that a full exhaust could. Upon revving the car out stationary and on the dyno, you could hear the tone change nicely as you past the 4000rpm mark.
According to our dyno test, the secondary muffler bypass pipes really start achieving performance from 3700rpm all the way to redline. With a baseline test in 3rd gear and all wheel drive (have to for the dyno and no warning lights), the car made 344HP and 289ft/lbs of torque. Based on the ambient temperature, the Mustang Dyno, and 91octane fuel, this is about right considering the car comes with 400bhp. With the addition of our pipes, the car put down 358HP and 298ft/lbs of torque gaining 14HP and 9ft/lbs at the peak. As you can see from the dyno plot, gains were higher and lower throughout the curve but always better then stock.
Contact us for pricing as these parts are available. Stay tuned for our next update which is involves High Flow Cat Equal Length Headers! You can also view other Porsche 991 Carrera Parts Here.
Old Jun 13, 2012 | 07:24 PM
Our next development project for the Porsche 991 Carrera is the high flow race headers. These headers are a big change in design compared to stock which now feature a 3 into 1 merge collector on either bank. The all stainless steel headers have an equal length design to improve the flow from the engine. Available in both catless and 200 cell high flow cats, we tested the more common version people will use with cats. To keep our modular focus, these headers are a direct OEM replacement. They allow you to run the stock main muffler and secondary mufflers or use our secondary bypass pipes.
Our two objectives for this product were to gain power and have no check engine light issues. To avoid the dreaded CEL, we actually put a O2 spacer on the secondary O2 to raise it up out of the stream so it would not read the change from the high flow cats compared to stock. Under an extensive period of time driving on the dyno like one would on the street, the car still never threw any CELs for us. So having a baseline of the car stock with around 342.8hp, we gave these bad boys a run.
An immediate difference was the sound. These headers really enhanced the sound of the 3.8L DFI engine. It was very GT3 sounding. When lifting off the throttle, it gave a little bit of back rumble. Without knowing the numbers, the dyno runs could be audibly and noticeably felt smoother through the RPMs. Once we finished our 3 runs, we looked at the graph and were quite amazed. Stock, the car has a very lumpy power curve. With our special 3 to 1 merge collector and equal length tube design, the power band became extremely linear and consistent with no hesitation or issues. In some areas of the curve it gained 30ft/lbs of torque! The Agency Power 991 Carrera Headers gained a peak of 11HP and 12ft/lbs of torque.
If I had to make a choice on which to buy first, exhaust or headers, I would choose headers for the Porsche 991. Check out the video and pics below!
Old Jun 14, 2012 | 08:53 PM
SM_ATL's Avatar
SM_ATL Is a GOD !SM_ATL Is a GOD !SM_ATL Is a GOD !SM_ATL Is a GOD !SM_ATL Is a GOD !SM_ATL Is a GOD !SM_ATL Is a GOD !SM_ATL Is a GOD !SM_ATL Is a GOD !SM_ATL Is a GOD !SM_ATL Is a GOD !
Wow! Can't wait to see the full combo + tune dyno!!!
Old Jun 15, 2012 | 09:00 PM
Psycho Sid's Avatar
Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !
Do you guys have pricing yet?
I'm interested in the 200 cell cats/headers, pm me with cost please.
Cheers.
Old Jun 17, 2012 | 05:42 AM
Cpa4S's Avatar
Cpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to behold
i love the almost plug & play approach. i think those bypass pipes brilliant
Old Jun 17, 2012 | 05:54 PM
1BlinkGone's Avatar
1BlinkGone is a name known to all1BlinkGone is a name known to all1BlinkGone is a name known to all1BlinkGone is a name known to all1BlinkGone is a name known to all1BlinkGone is a name known to all
Very appealing. Can't wait to hear the combination together. I like those headers. Any ceramic-coating options available for them, or is it even necessary?
Old Jun 18, 2012 | 09:24 AM
Will have both pricing and combined product updates today.
Old Jun 18, 2012 | 12:02 PM
split's Avatar
split is infamous around these partssplit is infamous around these partssplit is infamous around these partssplit is infamous around these parts
i wonder if anyone is going to do a long tube catless header with the merge collector placed right at the flange
Old Jun 18, 2012 | 12:15 PM
SM_ATL's Avatar
Does it/Will it include a tune to get the best out of it?
Old Jun 18, 2012 | 12:26 PM
Tuning is in the works, but not yet available because of the encryption of the new ECU just like the Panamera and Cayenne.
Old Jun 18, 2012 | 04:50 PM
We took both of our new Porsche 991 products and ran them installed on the car compared to stock. This included the 200cell high flow cat race headers and 2nd muffler bypass pipes. Combined, the increase was mainly in the torque giving the car about 14hp and 14ft/lbs gain over stock. The best part about the combined parts is the newly enhanced GT3′ish sound that the 991 now gives off. Here is the video with dyno sheet and photos of the parts installed.
Old Jun 19, 2012 | 12:16 PM
These 2 parts are now available for sale online - http://www.vividracing.com/catalog/s...che%20991.html
Old Jun 20, 2012 | 05:53 PM
RacingEngineV8's Avatar
RacingEngineV8 has much to be proud ofRacingEngineV8 has much to be proud ofRacingEngineV8 has much to be proud ofRacingEngineV8 has much to be proud ofRacingEngineV8 has much to be proud ofRacingEngineV8 has much to be proud ofRacingEngineV8 has much to be proud ofRacingEngineV8 has much to be proud ofRacingEngineV8 has much to be proud of
Wow...now the 991 sounds amazing!! It's incredible how many hp you can gain with this kind of exhaust...
Great car and great sound!
Old Jun 20, 2012 | 06:58 PM
Thank you
Old Jun 22, 2012 | 07:46 PM
SM_ATL's Avatar
The combined upgrade seems to be good value for money and I am very close to go for it.
2 questions:
-did you take sound level measurements? any idea about what peak dB you would get too (in other words am I going to wake up the neighborhood or be excluded during the 'quiet hour' at the track?). I know youtube videos have been posted but it is not easy to figure out how much louder the exhaust is.
-I already have the PSE option and I would think that both the bypass and the headers would work with it, right? The center muffler is separated in 2 parts with the valves in the middle, but all the rest seems to be similar. Can you confirm?
Thanks!
