Brake squeak
Old Sep 19, 2012 | 10:17 AM
nicoli's Avatar
nicoli has a reputation beyond reputenicoli has a reputation beyond reputenicoli has a reputation beyond reputenicoli has a reputation beyond reputenicoli has a reputation beyond reputenicoli has a reputation beyond reputenicoli has a reputation beyond reputenicoli has a reputation beyond reputenicoli has a reputation beyond reputenicoli has a reputation beyond reputenicoli has a reputation beyond repute
thanks for the video but I couldn't sit through the whole thing. Here is another link with quick instructions just by googling bedding brakes
Will try this a bit later today.
http://zeckhausen.com/bedding_in_brakes.htm
Old Sep 19, 2012 | 01:36 PM
ChuckJ's Avatar
ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !
Breaker841:
Great video, thanks for posting.
ChuckJ
Old Sep 19, 2012 | 02:20 PM
aamersa's Avatar
aamersa is a splendid one to beholdaamersa is a splendid one to beholdaamersa is a splendid one to beholdaamersa is a splendid one to beholdaamersa is a splendid one to beholdaamersa is a splendid one to beholdaamersa is a splendid one to behold
I have 12500 kms on mine and get the break squeal under the conditions described above. But I thought it was normal and it only happens occasionally so it doesn't bother me. If it starts happening more often I might look in to it. For now it's just one of the many mean noises this performance car makes.
Old Sep 19, 2012 | 07:28 PM
tachyon's Avatar
tachyon is a name known to alltachyon is a name known to alltachyon is a name known to alltachyon is a name known to alltachyon is a name known to alltachyon is a name known to all
I've had the same issue but it went away after 1500 miles or so. it was so annoying it drove me nuts. my dealer told me to do a hard brake while driving around 25-30 mph. it fixed.
Old Sep 21, 2012 | 01:24 PM
nicoli's Avatar
I did a few 60-70 to 10 mph stops a couple nights ago with medium-heavy pedal pressure, the brake noise is completely gone.
Old Sep 21, 2012 | 01:32 PM
See U n Rear View's Avatar
See U n Rear View is just really niceSee U n Rear View is just really niceSee U n Rear View is just really niceSee U n Rear View is just really niceSee U n Rear View is just really nice
Exclamation Huney, Where did you put the "Brakes" -->There in Bed...
that's Great Work! I was hoping that there would be an easier fix than installing rubber backed shims or Anti-Squeal...
I have used Zeckhausen's method before to simply Bed the brakes but didn't realize that it also eliminates Brake Squeal...
Porsche Should Have the Brakes Bedded prior to purchase... Well, it was just a thought...
Old Sep 21, 2012 | 01:42 PM
elam's Avatar
elam is infamous around these parts
Great to hear! I'll give that a try myself.
Old Sep 21, 2012 | 04:11 PM
chancemartenson's Avatar
chancemartenson is infamous around these parts
Originally Posted by Breaker841
This is extremely normal and expected on a high performance car. Proper bedding of the brakes WILL stop the squeal for a while and is a smart thing to do regardless. Your stopping distances will be much shorter and you will potentially save yourself from an accident. Oh yeah ABS doesn't need to kick in nearly as often too. If you need instruction on how to bed the brakes I can post a very informative video.
this my 6th new 911 never experienced this before. am surprised after 4k miles (w all types of very hard braking) still squeakers. my perception (not true of course), is that my 2011 ford F-150 raptor has better brakes than this car and that is a sad commentary. dealer more than willing to dive in take a look, i have chosen to live with it hoping it will go away. still hoping....
Old Sep 21, 2012 | 10:14 PM
chancludo's Avatar
chancludo is a splendid one to beholdchancludo is a splendid one to beholdchancludo is a splendid one to beholdchancludo is a splendid one to beholdchancludo is a splendid one to beholdchancludo is a splendid one to beholdchancludo is a splendid one to behold
Thanks, Breaker! I have exactly the same issue, although it's intermittent. It didn't start until about 2,800 miles on the car, though. Is that normal?
Old Sep 25, 2012 | 01:56 PM
elam's Avatar
I took my 991S into my local dealer to have its rear tire replaced - a nail in tire only after 300 miles
The service advisor performed the standard procedure to see if there is any applicable recall on my car. And BAM! A recall campaign on my rear brake pads. Something about the rear pads not up to Porsche quality and making too much noise under certain situations. The recall number is WC46.
I'll see if that helps with the squeak when I get the car back. Keeping my fingers crossed!
Old Sep 26, 2012 | 12:42 AM
Fester's Avatar
Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !
This is great news!
Old Sep 27, 2012 | 02:38 PM
msf's Avatar
msf
msf is infamous around these parts
I have over 37,000 on my TT and have never had brake squeal. That would be a deal breaker for me. Hopefully the new pads will fix this.
Old Sep 27, 2012 | 03:16 PM
elam's Avatar
I just got my car back. No brake squeal so far! For those of you who have the same issue, check with your dealer and see if WC46 is applicable to your car.
Old Oct 1, 2012 | 10:47 AM
Cool Squeal like a pig...Not....!
Thanks for the
Info Elam!
Repp'ed +1
Old Oct 1, 2012 | 09:06 PM
Woodster's Avatar
Woodster is a jewel in the roughWoodster is a jewel in the roughWoodster is a jewel in the rough
Thumbs up
I only had the brake squeal occasionally at low speed in the first 1400 miles. I did however have a lot of chatter at low speed coming to a stop, like driving on marbles. Both issues were becoming progressively worse starting at around 500 miles.
I followed the video recommendation of a fairly aggressive 10ea-60mph to 5mph in a row, followed by a short cool down period, then another 10ea-60 to 5 in a row. It's now 500 miles later and no more marbles or squeal. It was the marble thing that concerned me most, I was pretty sure that when that is happening braking distance suffers.
Thank you for the video Breaker, I was (as always) hoping there was a simple fix for these problems and this time there was!
I have had no "campaign" on brakes performed, I don't know if there is one on my car. It's a January 2012 build.
