Which is less stiff
Old Nov 19, 2012 | 07:47 AM
eg9's Avatar
eg9
eg9 is infamous around these parts
Which is less stiff
Out of the following models, which car rides stiffer and is the difference noticeable?:
1) C4S w/ PASM set on normal
2) C4 w/ no PASM & w/20" wheels
3) C2 w/ no PASM & w/20" wheels
(Assuming same tires and on the same roads)
Thanks In advance
Ed-
Old Nov 19, 2012 | 08:06 AM
ALPINE6SPD's Avatar
ALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant future
I would say 1
Old Nov 19, 2012 | 08:18 AM
exponential's Avatar
exponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to behold
1,2 then 3. They are already in order from stiffest to softest.
Old Nov 19, 2012 | 10:22 AM
eg9's Avatar
eg9
Is there a simple way of making he C4S less stiff without getting another model? I want the speed, looks and resale of the C4S but with the stiffness of the C2
Old Nov 19, 2012 | 10:24 AM
eg9's Avatar
eg9
Also here's another question... What makes the C4S more stiff than the C4 and C2?
Old Nov 19, 2012 | 12:45 PM
galion's Avatar
galion has much to be proud ofgalion has much to be proud ofgalion has much to be proud ofgalion has much to be proud ofgalion has much to be proud ofgalion has much to be proud ofgalion has much to be proud ofgalion has much to be proud ofgalion has much to be proud ofgalion has much to be proud of
You get higher spring rates with PASM
Old Nov 19, 2012 | 01:18 PM
eg9's Avatar
eg9
Is there an easy way to adjust settings on a C4S to make it less stiff?
Old Nov 19, 2012 | 02:18 PM
Havok's Avatar
Havok is a glorious beacon of lightHavok is a glorious beacon of lightHavok is a glorious beacon of lightHavok is a glorious beacon of lightHavok is a glorious beacon of light
1>2=3
Old Nov 19, 2012 | 06:00 PM
Psycho Sid's Avatar
Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !
Ok you guys I did quiet a bit of research regarding this issue and decided the best combo is the C4S with PDCC. for all the info on anti roll-bar specs per model as well as the spring rates etc check out post 385 and 391 on page 26 and 27 https://www.6speedonline.com/forums/...91-c4s-26.html
Cheers!
Old Nov 19, 2012 | 09:34 PM
eg9's Avatar
eg9
Thanks Sid... So if a C2 is 9N/mm softer setting than the C4S anti-roll bars, will adding PDCC and PASM to a C4S be similar to the comfort of a C2 with PASM & w/20"?
THanks
Old Nov 20, 2012 | 12:02 AM
Sidney1's Avatar
Sidney1 has a spectacular aura aboutSidney1 has a spectacular aura about
Hi!
There was just an article in "Auto Sport" - a german sports car magazine ... with main focus on real sports car ...... they´re writing that even Sport PASM ( SPASM ) delivers quite a good comfort on the C4S
Best
Gregor
Old Nov 20, 2012 | 06:35 PM
Psycho Sid's Avatar
THanks
Yep I'd say that statement is correct... but until we are actually able to drive it for ourselves it's all just deduction based on numbers and highly subjective comparison from journalist (most whom have never owned a 911...).
One thing though, PASM already comes with the C4S, S-PASM needs to be added separately...
I would say that it's all based on the experience I've had with the C2S
Cheers!
ModBargains
Bentley Vendor Classifieds
Oct 13, 2015 03:42 PM
ModBargains
Lotus Vendor Classifieds
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ModBargains
Oct 13, 2015 03:40 PM
carsnob
Sep 8, 2015 04:10 PM
