First oil change - help please
Old Jan 13, 2013 | 10:13 AM
last993's Avatar
last993 is infamous around these parts
Service reminder, 10+ days remaining till oil change message came up the other day. Two questions. Has anyone in the forum used the Durametric tool to reset the service reminder message and oil fill capacity, 7.5 qts or 9 qts ? TIA
Old Jan 13, 2013 | 10:31 AM
k4site's Avatar
k4site is infamous around these parts
yes it works
Old Jan 13, 2013 | 11:08 AM
eg9's Avatar
eg9
eg9 is infamous around these parts
I'm curious if we can use the Griots Oil Extractor for oil changes... It extracts as much (if not more) oil as a regular oil change.... Just wondering... My dealership charges $390 for 991 oil change.. (Ferrari 360 was $280)
Old Jan 13, 2013 | 01:42 PM
k4site's Avatar
Oil extractor will not work, but changing oil is not that hard. ( I own 996 and 997). I have a ind change it for $70 labor plus oil and filter and two crush washer it cost me about $145. I supply the washers, filter and oil
Old Jan 13, 2013 | 02:06 PM
last993's Avatar
thanks for the reply. The reason why i asked is because i remember reading the post in this forum that one member was having an issue of using the tool to reset the reminder. I am about to purchase the tool and want to make sure that it works.
Old Feb 17, 2014 | 05:04 AM
addysdaddy's Avatar
addysdaddy has a spectacular aura aboutaddysdaddy has a spectacular aura about
So how many quarts does the 991 C2s hold?
Old Feb 17, 2014 | 06:18 AM
rnl's Avatar
rnl
rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !
A little more than 10 however it may only drain 8 to 9+ quarts. It's potentially messy but I measure the amount drained and refill that amount. Because the filter holds a small amount I'm usually about 1/4 quart low.
Old Feb 17, 2014 | 06:44 AM
See U n Rear View's Avatar
See U n Rear View is just really niceSee U n Rear View is just really niceSee U n Rear View is just really niceSee U n Rear View is just really niceSee U n Rear View is just really nice
Good to know that the Durametric tool works as described
Old Feb 17, 2014 | 01:53 PM
rnl's Avatar
rnl
Didn't work for me and "customer service" wasn't.
Old Feb 17, 2014 | 07:58 PM
addysdaddy's Avatar
Thanks so much - appreciate the info.
Old Feb 18, 2014 | 06:40 AM
rnl's Avatar
rnl
It may be wasteful but considering that the drain is aluminum and so is the plug and they may be easily deformed I am also replacing the drain plug with the gasket. It's $5 or so.
Old Feb 18, 2014 | 07:04 PM
stevefrommn's Avatar
stevefrommn has a spectacular aura aboutstevefrommn has a spectacular aura aboutstevefrommn has a spectacular aura about
Over kill to replace the plug. I changed my oil for 13 years on my 996 and for the last 3 years on my 997. Always replaced the washer but never the plug.
Always tourqued it to spec and they showed no wear at all.
Old Feb 19, 2014 | 07:24 AM
addysdaddy's Avatar
What is the factory oil recommendation - Mobil 1 0w-40?
Old Feb 19, 2014 | 09:44 AM
eldertec's Avatar
eldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to behold
Yes.
Old Feb 19, 2014 | 10:27 AM
TAch Miami's Avatar
TAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond repute
Yes, since Exxon pays to be the recommended oil.
