porsche 991 problem
Old 01-15-2013, 10:35 PM
Fester's Avatar
Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !
Originally Posted by 19hole
This is VERY common with high performance tire compounds when they get cold. It is not limited to P Zeros, all brands do this. It will go away when the temps get back above 45°-50°F or you put winter tires on.
There is nothing wrong here....
Makes sense...hence not an issue on winter tires.
Old 01-15-2013, 10:42 PM
NSD991's Avatar
NSD991 is just really niceNSD991 is just really niceNSD991 is just really niceNSD991 is just really nice
Same issue here, appears to be normal, still sounds and feels horrible. Embarrassing when you have a passenger. Will change to Michellins if the consensus is that they are less likely to have a similar issue.
Old 01-15-2013, 10:46 PM
advantyper's Avatar
advantyper is a splendid one to beholdadvantyper is a splendid one to beholdadvantyper is a splendid one to beholdadvantyper is a splendid one to beholdadvantyper is a splendid one to beholdadvantyper is a splendid one to beholdadvantyper is a splendid one to behold
i got the exact problems as other 991 owners, the wind buffing noise with window down is the worst IMO
Old 01-16-2013, 06:48 AM
frank69m's Avatar
frank69m has a spectacular aura aboutfrank69m has a spectacular aura about
So it never gets cold in Germany / Europe when they first tested this?
Wonder if it would happen with a "4".
Old 01-16-2013, 10:21 AM
19hole's Avatar
19hole has much to be proud of19hole has much to be proud of19hole has much to be proud of19hole has much to be proud of19hole has much to be proud of19hole has much to be proud of19hole has much to be proud of19hole has much to be proud of19hole has much to be proud of
It is not a function of the difference between a C2 and a C4. It is purely a tire coumpound/tire width issue.
High performance tires (read: SOFT and WIDE tires with small, stiff sidewalls) are not designed to be used in cold weather. The rubber compounds get very hard and non-compliant. The driving experience has been described as "greasy", kind of like that when the roads have just a light coating of moisture on them. When the rubber gets cold and hard and you input very high steering angles the tire is not compliant enough to flex, it "hops" and that make both the ugly noise and provides quite a bit of feedback through the steering wheel.
Put snow/winter tires on the car and this goes away.
Old 01-16-2013, 10:45 AM
Detroit Shooter's Avatar
Detroit Shooter is infamous around these parts
Yup normal and very annoying. Don't hold it to the stops.
Old 01-16-2013, 10:59 AM
caveatesq's Avatar
caveatesq is just really nicecaveatesq is just really nicecaveatesq is just really nicecaveatesq is just really nice
Owner's use of seasonally inappropriate tires - must be a Porsche design flaw!
Old 01-16-2013, 11:11 AM
T-Mac's Avatar
T-Mac is a splendid one to beholdT-Mac is a splendid one to beholdT-Mac is a splendid one to beholdT-Mac is a splendid one to beholdT-Mac is a splendid one to beholdT-Mac is a splendid one to beholdT-Mac is a splendid one to beholdT-Mac is a splendid one to behold
Yup...cold weather issue. Don't worry, it will go away when it gets warm.
Old 01-16-2013, 12:27 PM
aamersa's Avatar
aamersa is a splendid one to beholdaamersa is a splendid one to beholdaamersa is a splendid one to beholdaamersa is a splendid one to beholdaamersa is a splendid one to beholdaamersa is a splendid one to beholdaamersa is a splendid one to behold
I have never experienced this. But that's probably because I live in a hellishly hot climate. This is a cold climate issue.
Old 01-16-2013, 01:10 PM
fantom's Avatar
fantom has a spectacular aura aboutfantom has a spectacular aura aboutfantom has a spectacular aura about
Porsche 991 problem......it gets dirty sometimes, and requires cleaning. ;-)
Old 01-16-2013, 01:29 PM
frank69m's Avatar
If it is a case with tires, do other performance cars with performance tires have the same issue :-)
Old 01-16-2013, 01:53 PM
Nuke986's Avatar
Nuke986 has a spectacular aura aboutNuke986 has a spectacular aura about
So glad you posted that little video.... mine sound that exact same way. I even posted 'Sounds like my front end is falling out' on this site. It really is embarrassing when you take someone out in your new Porsche and it sounds and feels like an old jalopy (at least for the first 10 feet). One would think that the world renowned engineers at Porsche could overcome this problem.
Old 01-17-2013, 09:49 AM
Snowczar's Avatar
Snowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to behold
This is not a design flaw but as mentioned above owners using the wrong tires in cold weather. In Germany the use of proper winter tires is mandatory. The high performance tires on our cars are not designed nor intended to be used at approx. 40'F and below.
John in Vancouver
Old 01-20-2013, 06:20 PM
Chupacabra's Avatar
Chupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond repute
Seems your post has become famous. As it is now being posted on the Carscoop Blog.
http://carscoop.blogspot.com/2013/01...-noise-on.html
Old 01-21-2013, 03:58 AM
19hole's Avatar
And every "helpful" post there is wrong!
Quick Reply: porsche 991 problem
