Clear side marker installation question
Old Jan 24, 2013 | 04:52 PM
991s's Avatar
991s is infamous around these parts
Can the side marker release clip be reached without taking the wheel well liner out?
Old Jan 24, 2013 | 05:13 PM
DBYT's Avatar
DBYT has a reputation beyond reputeDBYT has a reputation beyond reputeDBYT has a reputation beyond reputeDBYT has a reputation beyond reputeDBYT has a reputation beyond reputeDBYT has a reputation beyond reputeDBYT has a reputation beyond reputeDBYT has a reputation beyond reputeDBYT has a reputation beyond reputeDBYT has a reputation beyond reputeDBYT has a reputation beyond repute
Just pull it out. No need to take out the wheel well liner. Very simple.
Old Jan 24, 2013 | 05:27 PM
ChuckJ's Avatar
ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !
It's spring loaded.
ChuckJ
Old Jan 24, 2013 | 05:33 PM
dux's Avatar
dux
dux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond repute
Place your hand into the wheel arch and pop out the back-end of the marker.
Then simply slide out towards the rear of the car.
Extremely simple.
Old Jan 24, 2013 | 05:43 PM
STALKER's Avatar
STALKER is a splendid one to beholdSTALKER is a splendid one to beholdSTALKER is a splendid one to beholdSTALKER is a splendid one to beholdSTALKER is a splendid one to beholdSTALKER is a splendid one to behold
Where is the best place to get them?
Old Jan 24, 2013 | 05:47 PM
CarreraPete's Avatar
CarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud of
Some of them are tight and need a little finessing. Gently push in at the center of the marker with your thumb and slide it towards the wheel; use the forefinger and thumb of the opposite hand to lift the end of the marker while your pushing and sliding.
Once the unit is out, disconnect the plug and set the marker aside. Be very careful if the wire is taught; you'll still be able to remove the plug, but you'll be working closely to the fender. It can't hurt to place a microfiber cloth behind the marker while your tugging the plug off.
Install the new marker using the reversed sequence of steps.
Once the new units are installed, place the old ones on the floor and stomp them twenty times; this helps to relieve some of the stress the old markers caused.
Old Jan 24, 2013 | 05:53 PM
Naaranha's Avatar
Naaranha has a spectacular aura aboutNaaranha has a spectacular aura aboutNaaranha has a spectacular aura about
Here you go...looks pretty simple.
Old Jan 24, 2013 | 06:09 PM
frank69m's Avatar
frank69m has a spectacular aura aboutfrank69m has a spectacular aura about
If its that easy, I guess anyone can come up to your car and do the same :-)
Old Jan 24, 2013 | 06:12 PM
Psycho Sid's Avatar
Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !Psycho Sid Is a GOD !
Throwing a brick or keying your car is actually easier...
Old Jan 24, 2013 | 06:46 PM
991s's Avatar
Okay, I get it now, thanks.
Old Jan 25, 2013 | 02:19 AM
mdc's Avatar
mdc
mdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond repute
, and I wasted my $40+ from Suncoast...
Old Jan 25, 2013 | 04:00 AM
Psycho Sid's Avatar
Ahem... I "happen" to have some "extra" sets I can sell ya for cheap...
Bring a friend, get 2 for 1!!
Old Jan 25, 2013 | 04:47 AM
Nine XI's Avatar
Nine XI is infamous around these partsNine XI is infamous around these parts
Nice video makes it look simple. But, in the 2nd installation did you see how he had the screwdriver in his hand and how close the tip got the quarter-panel!!! I can't watch it again because I know if that was me I would have gouged the paint...
Old Jan 25, 2013 | 05:20 AM
nicoli's Avatar
nicoli has a reputation beyond reputenicoli has a reputation beyond reputenicoli has a reputation beyond reputenicoli has a reputation beyond reputenicoli has a reputation beyond reputenicoli has a reputation beyond reputenicoli has a reputation beyond reputenicoli has a reputation beyond reputenicoli has a reputation beyond reputenicoli has a reputation beyond reputenicoli has a reputation beyond repute
I didn't like the orange bulbs inside clear markers, so I tried these clear LED replacement bulbs:
http://aznoptics.com/index.php?main_...&products_id=8
They are super, super bright and color temp is almost perfect.
Old Jan 25, 2013 | 06:29 AM
PorscheCrazy's Avatar
Not sure but I think the "orange" is a requirement in the U.S. That is why the side markers come orange to US and white in Europe. When you change out to the clear markers, the bulb is orange for that reason.
