Pdk or Manual Transmission?
Old Aug 7, 2013 | 12:16 PM
  #61
bccars's Avatar
bccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant future
Again, we are debating PDK vs MT in a 991. I see no use in throwing race boxes into the equation !
Also, in the past we have discussed the lag you are talking about again. And back then I had it too. And I acknowledge that. But now my car has more miles on it and the lag has gone. The PDK is an adaptive/learning system, so I presume it recognizes my driving style and adapted accordingly, the shifts are INSTANTLY now (both with the paddles and the pdk shifter)!
Originally Posted by FullThrottle64
As someone who has been racing for over 15 years, I'm going to argue this point. The PDK decidedly does NOT increase the level of driver control. In fact, it sharply REDUCES the amount of driver control.
2) The delay between command input and actual shift. People that actually drive their cars at the limit don't like variable response times - they want things to happen RIGHT NOW when they give the machine a command. The comments re: Shumacher, Vettel, et al, are not relevant to the PDK, because the PDK doesn't respond at the speed of a true racing transmission - not even close. The shift itself happens quickly, to be sure, but the delay of the shift actuation is unacceptable in a $100K "high-performance" car.
Old Aug 7, 2013 | 12:19 PM
  #62
bccars's Avatar
Originally Posted by GreggT
OK but....I refuse to be refered to as the guy just...... "pootling around town, daily driving, bored with driving the car......" That's an insult.
Gregg, I'm sorry. Didn't mean to belittle you, nor anyone else. I can get carried away sometimes (that's what you get when you are -too- passionate about your car)!
Old Aug 7, 2013 | 12:24 PM
  #63
FullThrottle64's Avatar
FullThrottle64 has much to be proud ofFullThrottle64 has much to be proud ofFullThrottle64 has much to be proud ofFullThrottle64 has much to be proud ofFullThrottle64 has much to be proud ofFullThrottle64 has much to be proud ofFullThrottle64 has much to be proud ofFullThrottle64 has much to be proud ofFullThrottle64 has much to be proud of
Others brought up F1 technology as if PDK were an example of racing transmissions - I was just responding to that statement.
Seriously? If true, that's a very interesting development (and it might change my opinion of PDK).
What about the "launch lag" from a dead stop?
Old Aug 7, 2013 | 12:29 PM
  #64
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
Greg, if you read my post carefully, do you really believe that I think the only thing about driving a car is gas and brake when you take manual shifting out of the equation ? Or worse, do YOU think that it's only about gas and brake then ?
And for your comment about a third peddle is about being able to drive, is what marks the keen educated driver. Please, don't make me laugh. Everyone, literally EVERYONE (grannys, grandpas, you name it) over here masters the clutch. Why do some people keep thinking a manual transmission is proof of you manhood or driving ability. Where I live it is just trivial stuff !
'If you read my post carefully'......I was not referring to "ganny's, gandpas, and you name it"......I was refering to the guy to my left....coming into turn one at 155 in his shiney new Turbo.
Whatever.....done here.
As I said before....buy what makes you happy. Hopefully that's the goal.
Old Aug 7, 2013 | 12:34 PM
  #65
bccars's Avatar
Yes seriously ! Try to get a testdrive for a full day, so you can do more than 1000 miles and the pdk logic can adapt to your driving style ! Then you can feel for yourself I am not kidding !
Launch lag. Can't say FT. I still take it very easy off the line. No hard launches (I wouldn't even call them brisk launches), mini launch controls, or launch controls as of yet. So I haven't noticed any differences there. Just the "normal" gripping/slipping of the clutch as I drive away, just like it would in a Manual Transmission. I'll keep you posted when I notice things changing when I start lauching harder.
The engine hesitation at various rpms when reapplying the throttle IS still there though, allthough not always. Can't get my head around that one at the moment, but it is very very annoying ! Behaves like a turbo lag sometimes ! Crap !
Old Aug 7, 2013 | 01:04 PM
  #66
jaspergtr's Avatar
jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !
I'd speculate that the system isn't adaptive, it's YOU that is adaptive (programmed mentally that the shift takes '0.x seconds' to shift, so I'll click the paddle now - to engage the gear in the 10 feet I'm travelling at 'y' mph).
This was the point I was making during that discussion. As seamless as some of you point out that driving a manual clutch pedal becomes, it is equally as seamless to adjust shift points and react .1secs sooner (if people can actually tell the difference in .1secs).
The shift takes place faster than removing your hand from the wheel to grasp the stick than it does to click the button (or paddle). But somehow people program their brains to know that -"If I'm coming into a corner, I preposition my hand on the stick, in preparation to grab the shifter a split second before I press the clutch pedal." This is how seamless learning to shift the dual clutch car be. It just takes practice (I'd also speculate it takes a lot less practice to master this as it does a single clutch pedal).
(bccars - I'm not offering a counterpoint, just adding my own experience with the 911's PDK)
Old Aug 7, 2013 | 01:27 PM
  #67
bccars's Avatar
Jasper. I'm quite sure it's not that in my case. I've been very aware of the lag and the possibility of "mental" adaptation on my part. It really has gotten way faster to the point that it's instantly from pulling the paddle or pushing/pulling the pdk shifter when I'm driving briskly in sportmode. I also tested it in a straight line, so no mental reprogramming or anticipating the shift was necessary like it would when setting up for a corner.
And it wasn't like that in the past, there was a noticeable lag back then, just like FT64 always said. Granted in the past, I was not always in sportmode, and I was driving less briskly due to breakin restrictions (and the sportmode throttle map/throttle pedal travel shortening has a tendency to trick you into giving it more stick).
Old Aug 7, 2013 | 11:12 PM
  #68
yrralis1's Avatar
I completely disagree, like I already stated in my previous post.
To me a MT is for people pootling around town, daily driving, bored with driving the car at slow pace, so they need the distraction (which they call involvement) of shifting the car.
People that tend to drive briskly/fast appreciate the added level of control in a PDK so they can optimize their driving, ie scanning the road, scanning traffic, managing treshhold braking, car balance, hit their apexes, manage traction out of corners, ... and so on. A MT is by definition a slow shift were the clutch is open for a longer time, thus more time out of control, and more time wasted shifting that could be used efficiently on other key aspects of driving ! And it's the total package of driving fast, near or on the limit which I call involvement. It's then that you feel alive, feel your body tingle, feel the adrenaline of well executed driving commands.
Great post !! I agree with all of this but there is one snag .
PDK evolved tremendously in the last four years since Porsche introduced it to the 997. Drive a 2009 PDK car and it will seem so dated in contrast to todays 991 .
Despite the manual opting for a 7 speed the component retains its traditional element built on simplicity . It can be called dated but not in the same manner as with the dated PDK . Technology does not get the same free pass when the new system trumps the old (as a multi decade traditional component) .
When the car or its engine can not evolve as rapidly as the technology the relatively new car can feel like a used car very fast and at 120K a pop that's expensive .
Old Aug 8, 2013 | 05:26 PM
  #69
Targa Tim's Avatar
Targa Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond repute
That's why I stay with my old manual transmission as it is already outdated and will not get any worse than now.
Old Aug 8, 2013 | 05:44 PM
  #70
certified_prime's Avatar
certified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of light
Yeah, but Porsche did mess with the manual, adding Hill Hold and an e-brake.
Old Aug 8, 2013 | 06:37 PM
  #71
Zelig's Avatar
Zelig is infamous around these parts
Who makes the manual transmission for the 991
Does Aisin still make the 991 MT like they did for the 997? Anybody know?
Old Aug 9, 2013 | 02:06 AM
  #72
bccars's Avatar
No, both 991 PDK and MT are built by ZF
In depth info:
http://www.caranddriver.com/features...-pdk-tech-dept
Old Aug 9, 2013 | 07:31 AM
  #73
Zelig's Avatar
Mt
Great article...thank you!!!
bzimpfer
Sep 26, 2015 10:55 PM
GSP
Sep 9, 2015 05:31 AM
yumaverick
Sep 2, 2015 03:48 PM
pjb84
Sep 2, 2015 12:57 AM
