wheel offset c4s
Old Nov 12, 2013 | 03:10 AM
SISCOKID's Avatar
SISCOKID is infamous around these parts
wheel offset c4s
I'm looking for spare wheels for winter snows, the car has the stock sport techno wheels. I found a set of Carrera S OEM's online and the offsets are:
Front:51mm
Rear:70mm
Does any on know if these rims will work on the C4S, will I need spacers?
What are the offsets on the sport techno's?
Old Nov 12, 2013 | 06:24 AM
ma991's Avatar
ma991 has a spectacular aura aboutma991 has a spectacular aura aboutma991 has a spectacular aura about
The rears won't fit properly without massive spacers. I got aftermarket wheels for my winters and they are +40 in the rear and they fit perfect with no spacers.
Old Nov 12, 2013 | 07:39 AM
STALKER's Avatar
STALKER is a splendid one to beholdSTALKER is a splendid one to beholdSTALKER is a splendid one to beholdSTALKER is a splendid one to beholdSTALKER is a splendid one to beholdSTALKER is a splendid one to behold
You will need about a 20mm spacer out back to get a flush look.
The wheels may actually fit, but will sit inside the rear fender.
Old Nov 12, 2013 | 08:34 AM
SISCOKID's Avatar
thx guys
Old Nov 12, 2013 | 10:00 AM
barncobob's Avatar
barncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the rough
My 06 997 C4 has 09 P oem turbo wheels and they fit perfect
fronts were marked 51mm
backs were 56mm
Old Mar 21, 2014 | 10:50 AM
bpatel23's Avatar
bpatel23 is infamous around these parts
which exact brand and model of winter wheel for 991 C4S?
Which wheel/tires set worked for you on your 991 C4S?
Old Mar 21, 2014 | 12:24 PM
ma991's Avatar
I ended up going with these in black:
https://www.6speedonline.com/forums/...uger-mesh.html
I went with PA4's. +52 in the rears is stock but they recommended +40 which fit perfectly with no spacers.
The quality of the wheels is good and the price was right for a set of winters.
Here's a quick shot:
Name:	2013-10-26 17.50.41.jpg
Old Mar 21, 2014 | 12:32 PM
bpatel23's Avatar
Thanks for the quick response. Did you buy your set from http://www.getyourwheels.com/? Did they put in the TPMS as well? What should I be looking at for a total cost?
Old Mar 21, 2014 | 02:30 PM
FrstPorsche's Avatar
FrstPorsche is infamous around these parts
Ma991, did you use plastidip on exhaust like lettering? Going to be spraying badges black soon and would also like exhaust tips dark to match. thx
Old Mar 21, 2014 | 02:35 PM
ma991's Avatar
Sent you a PM.
Old Mar 21, 2014 | 02:48 PM
ma991's Avatar
I sanded the tips lightly and then applied this:
Amazon.com: Automotive Primer, Gray, 12 oz.: Home Improvement Amazon.com: Automotive Primer, Gray, 12 oz.: Home Improvement
and then the black version of this (can't find it on Amazon right now):
Amazon.com: Eastwood Silver High Temperature Exhaust Coating Paint Kit: Home Improvement Amazon.com: Eastwood Silver High Temperature Exhaust Coating Paint Kit: Home Improvement
A year later I have to touch up a couple of small places which I will do this summer, I didn't bake it in so it's probably my fault. The tips come off really easily with screw holding them.
I really like the look. I also got some spray paint and did the washer covers up front, same process but not the high heat paint.
Pretty simple DIYs, good luck with yours.
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
