help decide on C4 vs C2S
Old Jan 20, 2014 | 03:06 PM
socalsteve's Avatar
socalsteve is a name known to allsocalsteve is a name known to allsocalsteve is a name known to allsocalsteve is a name known to allsocalsteve is a name known to allsocalsteve is a name known to all
Any advice??? Give the dealer your phone number, have them fix all the issues and then have them call you...if they aren't fixed, don't walk, run away from this car!!! Something is seriously wrong...
Edit: was the car in Sports Plus? That could explain the lack of smoothness on take off. That mode on a PDK is pretty violent and pretty much made for track use only.
Old Jan 20, 2014 | 03:08 PM
dux's Avatar
dux
dux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond repute
Certainly not normal under any circumstances.
I'd let them have a look at it and then schedule another (cold) test drive.
What type of warranty does the car come with in Norway?
Old Jan 20, 2014 | 03:13 PM
larspronne's Avatar
larspronne is infamous around these parts
@socalsteve first in normal during warm up, then tried sport and sportplus which was actually a little smoother. probably because the faster throttle input i guess, as it felt like it wanted to stall when trying a smooth take off in normal...
5 year warranty on all new cars here
thanks!
Old Jan 20, 2014 | 03:18 PM
SM_ATL's Avatar
SM_ATL Is a GOD !SM_ATL Is a GOD !SM_ATL Is a GOD !SM_ATL Is a GOD !SM_ATL Is a GOD !SM_ATL Is a GOD !SM_ATL Is a GOD !SM_ATL Is a GOD !SM_ATL Is a GOD !SM_ATL Is a GOD !SM_ATL Is a GOD !
Yikes! Not normal at all. I have an E46 SMG too and the PDK is a thousand times smoother. not trying to freak you out, but this would certainly give me cold feet! (no pun intended)
Old Jan 21, 2014 | 02:25 AM
bccars's Avatar
bccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant future
NOT normal at all ! That car must have some issues !
Old Jan 21, 2014 | 09:14 AM
carsrmyvice's Avatar
carsrmyvice is infamous around these partscarsrmyvice is infamous around these parts
I would move along and find another car. Probably easily fixed but not worth the hassle since your in a position to avoid it. I have found pdk to be the finest transmission I have had the pleasure of using. Very very smooth in normal.
Oerding911
Jun 9, 2016 08:04 AM
airbusdrvr
Dec 27, 2015 07:43 PM
007 Vantage
Oct 8, 2015 08:35 PM
leevg
New Member Introductions
Sep 28, 2015 05:59 PM
no1joey
Sep 9, 2015 01:30 AM
