Sound Symposer Mod
Old Feb 17, 2014 | 09:23 AM
dyim's Avatar
dyim is infamous around these parts
I thought the sound symposer has something to do with the A pillars also?
Or is the A pillar involved in another P-car other than the 991? Maybe the Cayenne?
Old Feb 17, 2014 | 01:18 PM
Jim M.'s Avatar
Jim M. is infamous around these partsJim M. is infamous around these parts
Thanks Chris, just stuffed some foam down the tube from the cabin side and covered it with a piece of dynamat. Will also do the other end of the tube in a similar fashion.
Old Feb 17, 2014 | 03:43 PM
ChuckJ's Avatar
ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !
I thought the sound symposer only turned on with sport. If that's the case wouldn't disconnecting the actuator be simpler?
ChuckJ
Old Feb 17, 2014 | 04:19 PM
lunarx's Avatar
lunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to behold
ChuckJ
I heard you would get an error code, if the actuator was unplugged.
Also, that actuator is buried, behind the air cleaner, so getting to it is not easy.
It would be nice to remove the actuator & valve some day and figure out what is needed (resistor probably) to keep the error code from setting.
Old Feb 17, 2014 | 09:08 PM
MKW's Avatar
MKW
MKW is infamous around these parts
could one theoretically personalize the cabin sound by placing covers with different sized orifices or even musical instrument like diaphragms at the exit port under the carpeted cover so it is less drony / boomy and more high pitched or raspy per ones preference?
Old Feb 18, 2014 | 11:23 AM
Christophosphorus's Avatar
Christophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to behold
No problem. Lunarx's write-up should help get rid of the remaining sound entering the cabin.
You probably could, but I don't know if there is enough air traveling through the actual valve/tube to make a difference.
Originally Posted by Tom 991s
Interesting, I hadn't thought about the sensor ... Could catch oil I guess. Just saw the discussion on intakes on Serge's thread also. With previous cars I've had mixed experiences. Had an Injen cold air intake on my e46 m3 and that really made a difference. On earlier cars, I had some bad experiences of losing low end torque ... Need to make sure length supports the right resonance. Looks like the stock air box is somewhat nifty. But then the cup car has a simple big filter....now they don't care as much about low end torque I guess ;-)
Will hold off and see if someone posts some experiences. For now, I have the Bmc filters inside the stock air box and will leave it at that...
I had an intake and tune combination on my 2005 Mustang GT; it made a huge difference. Most of it, though, was a result of the tune itself. Installing an intake and a tune together helps tweak the AFRs and other parameters that may change as a result of increased air flow.
I would consider a GIAC tune / intake combo on our cars, but I'm (surprisingly) satisfied with the car in stock form.
Old Feb 26, 2014 | 12:05 PM
BradB's Avatar
BradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to all
I just performed this mod on my C2S. Wow! What an improvement. I can listen to the radio clearly now and enjoy the quiet and solidity of the car. The exhaust sound it still glorious but now outside the car where I want it. Best mod so far!
Old Feb 26, 2014 | 02:42 PM
dux's Avatar
dux
dux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond repute
What did you use for "stuffing"?
Old Feb 26, 2014 | 03:07 PM
BradB's Avatar
I used a tightly wound microfiber towel.
Old Feb 26, 2014 | 09:28 PM
Glad you're enjoying the difference! I felt the same way after I did this, especially when I still had the original PSE muffler installed.
Old Mar 23, 2014 | 10:34 AM
PQA's Avatar
PQA
PQA is infamous around these parts
Dumb question perhaps, but I'm new to Porsche. Would a dealer take the position that this mod voids any part of your warranty? Its seems really mechanically innocuous, but is Porsche **** about DIYs?
Old Mar 23, 2014 | 10:50 AM
If you're just stuffing the tube, I doubt they would even notice, let alone care. Even disconnecting the symposer won't raise any red flags in my opinion.
Keep in mind that Porsche can't legally "void" the warranty for this mod. They'd have to actually prove that the modification caused the failure/fault of another part, or the part itself.
Old Mar 23, 2014 | 01:48 PM
991TurboS's Avatar
991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light
Does the turbo have this symposer as well? I actually find myself wishing the exhaust was louder sometimes.
Old Mar 24, 2014 | 11:32 AM
rjn21's Avatar
rjn21 is infamous around these partsrjn21 is infamous around these parts
Turbo /S has same sympose system. The exhaust sound is very muted as standard - way quieter than C2 etc with PSE.
Old Mar 24, 2014 | 12:05 PM
fbroen's Avatar
fbroen is a splendid one to beholdfbroen is a splendid one to beholdfbroen is a splendid one to beholdfbroen is a splendid one to beholdfbroen is a splendid one to beholdfbroen is a splendid one to behold
I stuffed some packaging foam in the the cabin inlet back in 2012. Have enjoyed the exhaust noise from the outside much more since.
And prefer hearing mechanical whining of things more so than the intake / symposer that I found sounded about as good as a cheap stereo bass speaker.
