First Oil Change
Old Apr 23, 2014 | 08:48 PM
Expect212's Avatar
Expect212 is infamous around these parts
First Oil Change
Its almost been a year so i scheduled my oil change for tomorrow at 10am, I'm getting a loner and was wondering how long does it usually take for them to do it, as well as what kind of loner do they typically give you.
Old Apr 23, 2014 | 09:36 PM
dux's Avatar
dux
dux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond repute
The loaner depends on the dealership and availability.
Cayman, Cayenne and Panamera's are normal. Sometimes you'll get a cheap Enterprise rental.
Oil change should take no more than 60 - 90 mins but prices are all over the place.
Old Apr 24, 2014 | 07:15 AM
MikeDi's Avatar
MikeDi is infamous around these parts
My dealership took 2 hours. I asked why so long and they said they let it drain for an hour. Don't know if that is really necessary or if this is standard. It was my first oil change as well.
Old Apr 24, 2014 | 07:35 AM
barncobob's Avatar
barncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the rough
do it yourself, its easy and cheap,,i drain mine and let it drain all night, refill in morning
Old Apr 24, 2014 | 08:41 AM
wanderfalke's Avatar
wanderfalke is infamous around these parts
how do reset the oil change notice the computer brings up? the price here in southern cal. for a oil change is 259 dollars at the dealership.
Old Apr 24, 2014 | 12:09 PM
scatkins's Avatar
scatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond repute
Get a durametric tool...
Although $259 is on the the reasonable side (at leat for a Porsche dealer). For that I'd almost just let them do it..
But I tend to like changing my oil at a higher frequency (5K miles for the 991) so I just do it myself. I also don't subscribe to the obsession to let it drain for hours to get every single drop of a 9 Quarts sump. Even if you think you got it all you never would anyway because there are likely places oil pool in an engine anyway that would never drain out. And the actual volume of oil that is left is insignificant.
Just pop it open, come back in 30 or 40 minutes, put on the new filter and then button it up. Takes a total time investment on my part of about 15 minutes.
Then take the money I save and go out to dinner with the wife..
Old Apr 24, 2014 | 12:14 PM
scatkins's Avatar
They may say that but the real reason is because the same guy is working on multiple cars simultaneously.
Old Apr 28, 2014 | 08:28 AM
beemer guy's Avatar
beemer guy is a jewel in the roughbeemer guy is a jewel in the roughbeemer guy is a jewel in the rough
If you don't let it drain for at least 45 minutes you run the risk of over-filling.
I'm still chuckling over the "loner".
Old Apr 28, 2014 | 10:43 AM
Christophosphorus's Avatar
Christophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to behold
Which SoCal dealership quoted you $259?
Old Apr 28, 2014 | 10:48 AM
Richard911's Avatar
Richard911 is infamous around these parts
My Florida Dealer was $400 less PCA discount
Old Apr 28, 2014 | 10:57 AM
tommyboy214's Avatar
tommyboy214 Is a GOD !tommyboy214 Is a GOD !tommyboy214 Is a GOD !tommyboy214 Is a GOD !tommyboy214 Is a GOD !tommyboy214 Is a GOD !tommyboy214 Is a GOD !tommyboy214 Is a GOD !tommyboy214 Is a GOD !tommyboy214 Is a GOD !tommyboy214 Is a GOD !
Park Place in Dallas is 199 for an oil change.
Old Apr 28, 2014 | 11:28 AM
CO997's Avatar
CO997 has much to be proud ofCO997 has much to be proud ofCO997 has much to be proud ofCO997 has much to be proud ofCO997 has much to be proud ofCO997 has much to be proud ofCO997 has much to be proud ofCO997 has much to be proud ofCO997 has much to be proud ofCO997 has much to be proud of
I just did mine at the dealer and it was $330 I think. However they called it my first year service and oil change. So they checked over everything I guess and also changed the oil. Just an oil change is much cheeper I suppose. I think going forward I'll probably change my own oil, especially if it's before the normally scheduled time. But ill need the dealer to reset the service notification unless you buy your own tool to do that.
Old Apr 28, 2014 | 11:30 AM
scatkins's Avatar
Not really.. When you fill you, don't blindly put in 9 quarts.. You fill based based on what is needed based on dip (or electronic dip as is the case for the 991). And the replacement qty varies, depending if you change the filter (I typically change oil at about half the recommended mileage, but do change the filter at at standard intervals). [Not wanting to debate the oil change frequency as that has been done endless]
When you drain oil, it isn't so much about waiting for a specific period of time, rather it is about waiting until what is draining out is down to a drip.. If stuff is still draining out that amounts to a significant amount in terms of qty, then if course you let continue.
That said I agree about 35 to 45 minutes seems like a reasonable time.
Old Apr 28, 2014 | 03:50 PM
ChuckJ's Avatar
ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !
Have you done a 2 year with them yet? How much was it?
ChuckJ
Old Apr 29, 2014 | 09:05 AM
San Diego Porsche I will report back on cost when I actually do it .
