Jackpoint Jackstands, a slick bit of kit
Old Jun 5, 2014 | 08:24 PM
tooltimer's Avatar
tooltimer is infamous around these parts
Originally Posted by lunarx
My brand new set of JackPoint JackStands are for sale, if anyone is imterested.
My Jack Arm is too wide to clear the sloted opening.
So I never even used them.
I might be able to help.
Old Jun 5, 2014 | 08:36 PM
tooltimer's Avatar
Originally Posted by paradocs98
Dr. C--
It is an ingenious design, allowing you to both jack the car and support the car on stands using the same designated jacking point. I have a set myself, with the low-profile pads, but I can't get my jack underneath the car when the pad is positioned on the jack's saddle. I'm using an older Griot's-branded aluminum racing-style jack, which appears to be almost identical in design to the one you're using--from the pics it looks like you have a Pittsburgh/Harbor Freight jack.
I need about 1.5cm or so more clearance to get the jack with pad under the car--the only way to get it to work is to take another jack and slightly lift the car beforehand on the other jacking point on that side, which kind of defeats the purpose of this slick design.
Either your jack has 2cm or more low-profile clearance than mine (which I doubt), or your car doesn't sit as low as mine. Do you have SPASM or regular PASM?
Try lifting the car on the lift point where you want to put the jack stand without the pad in place and then let the car down. Sometimes that will extend the suspension enough to get that extra clearance you need. You can also do the same thing and slide a short piece of 2x4 under the tire and let the car down. Now you'll have the extra clearance, you won't need to use 2 jacks, and you can work from a single location to jack up the first corner.
Old Jun 5, 2014 | 11:26 PM
lunarx's Avatar
lunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to behold
Apologies tooltimer, but someone just grabbed them today.
They are really cool and I wish they fit my jack.
Now I'm going to order the LiftBars
http://liftbars.com/index.htm
Old Jun 6, 2014 | 06:07 PM
kitw's Avatar
kitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud of
[QUOTE=lunarx;4128927]Apologies tooltimer, but someone just grabbed them today.
/QUOTE]
I have a set of liftbars. They are very nice, but a bit unwieldly due to length/weight/etc. Makes it really easy to get the car up, though!
Old Jun 6, 2014 | 09:24 PM
tooltimer's Avatar
/QUOTE]
I actually meant help solve the jack fit problem or refund your money if you wanted to return them. Sorry they didn't work out.
Old Jun 6, 2014 | 11:28 PM
John's 991's Avatar
John's 991 is infamous around these parts
Those lift bars look like just what I was looking for! I think I will order a set of those as well.
Old Jun 7, 2014 | 12:02 AM
lunarx's Avatar
tooltimer, I appreciate that.
It was close, but it seemed like the upper part of the slot was too narrow.
Perhaps some strategic grinding could have solved the problem.
Old Jun 7, 2014 | 12:07 AM
lunarx's Avatar
kitw, Thanks for the review. I'm looking forward to getting a set.
Old Jun 7, 2014 | 12:24 PM
Tom 991s's Avatar
Tom 991s is just really niceTom 991s is just really niceTom 991s is just really niceTom 991s is just really niceTom 991s is just really nice
Have had a pair of jackpoint stands for 6 months and absolutely love them ... low profile pads are great for the 991, though I need to drive on a 2-by-4 to get enough clearance for the jack.
Have a second set of slotted pads for the same stands that I use for my wife's infiniti - fantastic for lifting a car with jack points around the pinch weld ... some people are literally slotting hockey pucks ...
Old Aug 17, 2015 | 05:59 PM
john45in's Avatar
john45in is infamous around these parts
Just did my first oil change on a 13 C4 using 4 Jackpoint stands. Really gets the car up in the air to remove and retighten the oil drain plug. Their website describes the low profile jack dimensions and got one from Harbor Freight. A great product and aid!
Old Aug 17, 2015 | 06:56 PM
powdercoatmike's Avatar
powdercoatmike has a spectacular aura aboutpowdercoatmike has a spectacular aura about
really cool stuff! Might need to get a set. I use 4 of these on my racecar (Nissan). Had a lugnut welded on the end and use my electric impact to raise the car when I need to change pads or tires trackside.
deckman
Jun 17, 2024 12:55 AM
Payton34ferrari
Bentley
Dec 28, 2015 07:58 PM
timf
Nov 5, 2012 12:09 PM
BLKonBLK911C4S
Aug 23, 2012 03:29 PM
w00zie
Mar 20, 2010 09:08 PM
