Engine mount stiffening , is it noticeable?
Old Oct 15, 2014 | 12:20 PM
casaforte9's Avatar
casaforte9 is infamous around these parts
While Speccing my 991 PDK car, I am wondering if i need the sport chrono
I now have a boxster S pDK with Sport Chrono, PSE , paddles etc
I am not sure the value of SPort chrono if i do not care for gmeter , clock and sport plus as Sport is Std on the car. I also do not Track the car to use max RPM in auto mode
After owning the 981S for 18 months, I am not sure what sport plus enhances in manual mode since sport in manual mode has the same shift speed, shift feel and same pse sound levels compared to sport plus
So on a 991 with sport chrono , do the engine mounts stiffening make a noticeable difference in handling ?
Old Oct 15, 2014 | 03:29 PM
Chupacabra's Avatar
Chupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond repute
In your case, I would think you would not need it. You listed every reason why, to you, it's not necessary. The real gain of the sport chrono is found on the track and the Launch Control.
I'm sure others will say what it's worth. There have been several threads on this already. If you are not sure you need it, then you probably don't.
As for telling the difference with the engine mounts, no idea. I haven't been in one without Sport Chrono.
Old Oct 15, 2014 | 03:51 PM
todd92's Avatar
todd92 is infamous around these parts
I'm still getting it straight, but I'm fairly sure that with PASM, PSE and SChrono on my 7MT:
Sport - sharper throttle response, PSE open, auto start/stop off
Sport+ - Sport plus PASM stiff, PSM threshold higher
The dynamic engine mounts stiffness do not change with sport settings.
PDCC, if equipped, gets stiffer in Sport+,
PDK gets higher shift points in Sport, and faster, redline shift points in Sport+. In addition, Sport+ would allow Launch Control to be used.
I do not notice the sharper throttle response, PSE can be turned off/on independently, PASM can be stiffened independently, and PSM can be turned off.
So on a 7MT, SChrono gets you dynamic engine mounts, a silly stopwatch/clock and a Sport+ button whose functions can be obtained separately. I can't say if the engine mounts alone are worth it (haven't driven one without), but in reality that's all you're getting.
Old Oct 15, 2014 | 04:49 PM
991TurboS's Avatar
991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light991TurboS is a glorious beacon of light
I can definitely tell when I have the active suspension on vs off.
Old Oct 15, 2014 | 05:41 PM
todd92's Avatar
I can tell when PASM is set to stiff also, that isn't what the OP asked.
Old Oct 15, 2014 | 06:16 PM
991TurboS's Avatar
OK....not pasm...dynamc engine mounts. My mistake.
Old Oct 15, 2014 | 07:30 PM
991carreradriver's Avatar
991carreradriver has a spectacular aura about991carreradriver has a spectacular aura about991carreradriver has a spectacular aura about
Originally Posted by casaforte9
While Speccing my 991 PDK car, I am wondering if i need the sport chrono I now have a boxster S pDK with Sport Chrono, PSE , paddles etc I am not sure the value of SPort chrono if i do not care for gmeter , clock and sport plus as Sport is Std on the car. I also do not Track the car to use max RPM in auto mode After owning the 981S for 18 months, I am not sure what sport plus enhances in manual mode since sport in manual mode has the same shift speed, shift feel and same pse sound levels compared to sport plus So on a 991 with sport chrono , do the engine mounts stiffening make a noticeable difference in handling ?
In my view, you have a made very sound arguments to indicate that Sport Chrono is not meaningful to you. The one argument that does not favor you, is resale. Unless, you are leasing, your resale will certainly be compromised due to lack of market interest in a car without SC. Even though you may not enjoy its benefits, others do & I sense you are in a minority position. Why limit your resale market? On a technical note, the change in throttle response, steering, gearing & active suspension make a world of difference to an enthusiast.
Frank C.
Old Oct 15, 2014 | 07:35 PM
STG991's Avatar
STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !
Originally Posted by 991carreradriver
In my view, you have a made very sound arguments to indicate that Sport Chrono is not meaningful to you. The one argument that does not favor you, is resale. Unless, you are leasing, your resale will certainly be compromised due to lack of market interest in a car without SC. Even though you may not enjoy its benefits, others do & I sense you are in a minority position. Why limit your resale market? On a technical note, the change in throttle response, steering, gearing & active suspension make a world of difference to an enthusiast. Frank C.
Right on! Saved me some typing. Cars that don't have it suffer being lonely on dealer lots. They should have happy owners.
Old Oct 15, 2014 | 10:23 PM
Sloopy's Avatar
Sloopy is a glorious beacon of lightSloopy is a glorious beacon of lightSloopy is a glorious beacon of lightSloopy is a glorious beacon of lightSloopy is a glorious beacon of light
All 911 suffer some from movement of the engine though a lot of people don't have the feel for a car enough to notice it. When the car rotates the engine lags a little at first and then will continue when you stop the amount of yaw you want. Think of a car or truck pulling a trailer. Same thing only minute. This is why they hard mount the engines in the cup cars.
Sport chrono with reduce engine movement when you don't need it an still help to isolate the engine vibration when you don't want it. Since I tend to drive my cars with sprit I would not want a 911 without. Have not driven both back to back and standard car without still drives marvelous but the reason behind it can't help but make a difference.
Old Oct 16, 2014 | 01:02 AM
bccars's Avatar
bccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant future
To the OP's question "Engine mount stiffening , is it noticeable?" I can only say:
I do not notice it in my current use case, no track, spirited backroad driving.
Old Oct 16, 2014 | 01:25 PM
ChuckJ's Avatar
ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !
Frank C.
I completely agree with Frank. I thought long and hard about spending the money for SC because I thought I would never use launch control. My dealer recommended it for resale and I ordered it. I have never used launch control on my car and I still don't regret getting it. First, you probably will never be able to upgrade it after the fact and second, I like the vibration damping in the engine mounts. Save your money on the Bose and get SC and the HD radio.
ChuckJ
Old Oct 16, 2014 | 02:06 PM
Originally Posted by ChuckJ
I have never used launch control ....
ChuckJ
I thought I was the only person on this forum with SC that never used launch control. I am still wondering how I will ever use it. When I track my car, it is of no use for obvious reasons. When I autocross, the first turn always seems too close to the start line to make any sense. I thought about it once, but didn't think I could slow the car down in time to make the turn.
So, for the rest of the forum users of launch control, how and when do you use it? I truly am perplexed about its value.
Old Oct 17, 2014 | 02:57 AM
bccars's Avatar
I also never have used LC !
Old Oct 17, 2014 | 07:47 AM
scatkins's Avatar
scatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond reputescatkins has a reputation beyond repute
I thought I was the only person on this forum with SC that never used launch control. I am still wondering how I will ever use it. When I track my car, it is of no use for obvious reasons. When I autocross, the first turn always seems too close to the start line to make any sense. I thought about it once, but didn't think I could slow the car down in time to make the turn. So, for the rest of the forum users of launch control, how and when do you use it? I truly am perplexed about its value.
It really is just a gimmick.. It's one of those things you try once just to check it out and never use again..
In general I'd not get sc on my next 911... I bought into that resale argument but i think it is a rationalization... The dynamic engine mounts are another thing that have negligible value as well unless you push the car very hard in turns..
Old Oct 17, 2014 | 12:30 PM
ChuckJ's Avatar
I have experienced it on a dealer test car and thought it was great fun. It's just not one of those things that is usable in the world I drive. I do love the mini-launch control where RPMs surge to 3500 on start and I'm not sure if that's a function of an SC capable PDK or if it's in all PDKs.
ChuckJ
Jul 29, 2019 11:13 AM
Sep 10, 2015 03:20 PM
The Oss
Aug 24, 2015 08:19 PM
pwdrhound
Aug 23, 2015 07:36 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
