Need help on a ongoing exhaust upgrade
Old Nov 25, 2014 | 06:32 PM
STG991's Avatar
STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !
If my car wasn't away in storage, I'd put my old ones on there just to prove it.
I have my non-PSE ones at home. If anyone has the ones on their PSE now, I'd be more than happy to compare them!
Old Nov 25, 2014 | 06:33 PM
wanderfalke's Avatar
wanderfalke is infamous around these parts
Originally Posted by wanderfalke
Keep in mind that you need to supply a vin. no. to make sure you are buying the right switch panel.
Old Nov 25, 2014 | 06:38 PM
Originally Posted by drcollie
Not true. If you have an "S", you have the same tips that are used on the factory Sport Exhaust, and even if you needed a set, they're not $ 1,600. I've played around so many times with 991S tips I can do them blindfolded now.....the tips are held one with one clamping female TORX screw - only the base 991 has a different exhaust on it. He's probably confusing it with that.
Are those the tips that came on the CS standard exhaust retrofited on the PSE ?
Old Nov 25, 2014 | 06:49 PM
STG991's Avatar
Correct on the switch panel.
STG991's Avatar
Non PSE C2S tips
The only difference between the ones that came with the PSE is they were chrome and not brushed.
ID:	408570   Click image for larger version
ID:	408571   Click image for larger version
ID:	408572   Click image for larger version
Old Nov 25, 2014 | 07:47 PM
drcollie's Avatar
drcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond repute
That is a 100% stock 2014 Carrera S exhaust. Non-PSE. I have had those tips on an AWE exhaust and now they are on my TUBI. As you can see in these photos, the stock 991S (non-PSE) outlets are the same as all the aftermarket pipes. Here is what your stock 991S pipes look like with no tips:
And here's the TUBI. It may be difficult to see how the outlets are the same on this and all other aftermarket pipes (including the Porsche PSE) but they all end the same way at the outlets.
Old Nov 25, 2014 | 07:51 PM
STG991's Avatar
drcollie -- Awesome pics!
Exactly correct!
Old Nov 26, 2014 | 12:23 PM
Squires9914s's Avatar
Squires9914s is infamous around these parts
Just got off the phone with suncoast Unfortunately the tips are part of the kit and they can't break it apart ...so I have to pay full price $2,595.00
Old Nov 26, 2014 | 12:43 PM
STG991's Avatar
Well, they get you one way or another!
Oh well. You'll have an extra set of exhaust tips! You will see they both fit the PSE.
Still not a bad deal.
Old Nov 26, 2014 | 03:34 PM
911cv's Avatar
911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold
Did you order the parts individually minus the tips .
I ordered everything individually. Total for parts and labor was $2k.
Old Nov 26, 2014 | 03:35 PM
911cv's Avatar
Also, I started a how-to add PSE thread a few months ago...just in case you want to check it out.
Old Nov 26, 2014 | 03:36 PM
STG991's Avatar
Please post a link to it. Thanks
A Rennlist guy is asking questions that you've covered before. These topics recycle themselves. Why reinvent the wheel?
Old Nov 26, 2014 | 04:15 PM
911cv's Avatar
Originally Posted by STG991
Please post a link to it. Thanks A Rennlist guy is asking questions that you've covered before. These topics recycle themselves. Why reinvent the wheel?
Here you go: https://www.6speedonline.com/forums/...ts-prices.html
Also, be sure to go those tips ceramic painted black 😜
Old Nov 26, 2014 | 04:17 PM
STG991's Avatar
Here you go: https://www.6speedonline.com/forums/...ts-prices.html Also, be sure to go those tips ceramic painted black dde1c
Nice job!
I powder coated to match my wheels.
Old Nov 26, 2014 | 08:44 PM
Non PSE C2S tips
O.K. My PSE exhaust was installed without issue using the existing tips from the CS4 stock exhaust. If you look on the Suncoast add for the exhaust parts for my model they show a set of chrome tips for the non PSE and state they will not fit the PSE. Something is really out of whack.
