annoying Window Auto-Return issue
Old Dec 10, 2014 | 09:43 AM
TRM's Avatar
TRM
TRM is infamous around these partsTRM is infamous around these parts
as you know the 991 has this feature that the windows drop down about 1/4-1/2" upon opening the door...so the glass clears the body and molding. then once you close the door, the window returns to it's fully closed position.
after i did my AWE Foiler install i've noticed that the window doesn't always return to fully closed because it's actually opening too far...over 1/2" in travel.
i'm thinking this might be a simple adjustment...or something came loose when i removed the inner door panel during the install.
anyone else have this happen?
Old Dec 10, 2014 | 10:02 AM
991C4s's Avatar
991C4s is a splendid one to behold991C4s is a splendid one to behold991C4s is a splendid one to behold991C4s is a splendid one to behold991C4s is a splendid one to behold991C4s is a splendid one to behold991C4s is a splendid one to behold
You have to lower the window and keep the switch press for a few seconds after the window is completely down. Now do the same closing the window. It happens every time the battery is disconnected.
Old Dec 10, 2014 | 11:30 AM
PorscheCrazy's Avatar
Like C4s stated, windows must be reset. My understanding is that hold the switch when it is completely up too. I guess try both and see which one works:
To reset (car must be on):
1) lower the window all the way down and release the switch
2) push the switch down, hold it there for 3 seconds, and then release
3) raise the window all the way and release the switch
4) pull the switch up, hold it for 3 seconds, and then release
5) turn car off and then back on
Old Dec 10, 2014 | 03:29 PM
TRM's Avatar
TRM
You guys rock! Thanks for the reply and thankfully easy fix too.
Old Dec 11, 2014 | 08:03 PM
See U n Rear View's Avatar
See U n Rear View is just really niceSee U n Rear View is just really niceSee U n Rear View is just really niceSee U n Rear View is just really niceSee U n Rear View is just really nice
Thanks for the tip!
Old Dec 11, 2014 | 11:40 PM
2cardinalalums's Avatar
2cardinalalums is infamous around these parts
I have to give this a try. I think the previous version of instruction that I tried before didn't have the "release" between step 3 and 4.
The_Ruski_Driver
Oct 25, 2015 08:40 PM
gulf gt
Aug 27, 2015 10:27 AM
'02996ttx50
Aug 26, 2015 05:56 AM
richard2966
Bentley
Aug 22, 2015 03:33 PM
Aug 19, 2015 06:55 PM
