Light Weight Batteries
Old May 9, 2015 | 09:12 PM
lunarx's Avatar
lunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to behold
Originally Posted by Squires9914s
So i48CE would be fine with our 991. How's about fitment Are they exact fit? Any adapt or custom mount needed?
It's a Group 48, which is what fits our cars
It should be fully compatible with our tray and battery hold down bracket.
(Group 49 is wider so, for one of those, you just need to move the hold down out to the 3rd screw position.)
Only slight concern I see is the height of the i48CE.
It's significantly lower in height at 5.5" .
I think that still leaves enough down clearance, for the cable terminal blocks.
The i48CX is closer to factory battery height and may be a safer bet, for that downward clearance.
However, I do believe either height will work fine.
Old May 10, 2015 | 12:06 PM
Squires9914s's Avatar
Squires9914s is infamous around these parts
Thank you again Lunarx I really appreciated your time.
Old May 11, 2015 | 10:46 AM
lunarx's Avatar
Squires, your Trailblazing of 991 mods is an inspiration to us all.
Your 4S is true perfection.
J9277655
Dec 28, 2015 11:01 PM
Sales@RSW
Sep 3, 2015 09:34 AM
GSR Autosport
Aug 26, 2015 05:20 PM
TrackOne
Aug 20, 2015 12:56 PM
