Awd to rwd fuse conversion
Old Sep 1, 2015 | 01:39 PM
Nfall's Avatar
Nfall has much to be proud ofNfall has much to be proud ofNfall has much to be proud ofNfall has much to be proud ofNfall has much to be proud ofNfall has much to be proud ofNfall has much to be proud ofNfall has much to be proud of
Hello,
I was told that there is a fuse to cut power to the front wheels. Has anyone heard about this and will it cause damage?
I was told by a pretty reliable source ( that must stay anonymous) that this can be done and causes no damage.
I do not know what fuse it is btw. Does anyone know anything about this?
Old Sep 1, 2015 | 02:06 PM
plenum's Avatar
plenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant future
Originally Posted by Nfall
Hello,
Take a look in your owners manual... Pages 258 thru 260 list all the fuse box slots and indication of what purpose they serve. I see at least two fuse positions that serve "Allwheel Control Unit"(panel in passenger footwell, Rows B and D). You could pull one or both and see what effect it has.... But there isn't one labeled RWD or FWD for that matter. The AWD Control Unit is likely on the CAN BUS, receives telemetry from other controllers regarding power, wheel speed at the rear, steering angle and what not, and adjusts power to the front drive as needed. Eliminating the control unit effectively stops that all from happening.
But more importantly, why would you want to do this? To eliminate any power going to the front drive for some reason? Not sure that makes any sense given how the all wheel drive platform works. Nearly all power goes to the rear in my experience (I have a '14 C4S) until I am in a situation where some power needs to give the front some grip.... So effectively you have an RWD car much of the time.
What is your project?
Old Sep 1, 2015 | 04:56 PM
Nfall's Avatar
Dont get me wrong I love the stock system alot. Just wanted to play around with full time rwd and feel how the difference was. There is nothing like a full time rwd. (My opinion)
Old Sep 1, 2015 | 05:28 PM
Christophosphorus's Avatar
Christophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to behold
+1 to Plenum's response. I wouldn't do it. Disconnecting the system doesn't turn the car into a perfect RWD system, and there are dozens of systems that will still be working as if the car were AWD. What you will feel is not going to be a true RWD experience, and the workaround won't be worth it.
Old Sep 1, 2015 | 07:57 PM
westloop's Avatar
westloop is infamous around these parts
If you're serious about doing this - there is a lot of knowledge on the topic in the 997 forum.
I think a RWD Turbo would be a lot of fun, think GT2.
Good luck and let us know how it turns out. I'm rooting for you.
Old Sep 1, 2015 | 08:08 PM
powdercoatmike's Avatar
powdercoatmike has a spectacular aura aboutpowdercoatmike has a spectacular aura about
to go to true RWD, you would have to gut the front system. Even disconnected, you will still have a lot of drag from all of the parts still turning if you don't. I've got a friend that did it on his older turbo track car, and it wasn't a cheap proposition.
matt2ace
Nov 23, 2019 11:38 AM
adnanm3
Oct 25, 2016 08:38 AM
flewis763
Oct 4, 2015 04:14 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
gliozzi
Bentley
Sep 29, 2015 09:27 AM
