Need help with torn wheel well trim
Old Feb 29, 2016 | 03:34 PM
mad_max's Avatar
mad_max is infamous around these parts
The wheel well trim piece at the bottom is torn as you can see in the picture. Dealer says it can't be replaced under warranty because it probably got caught on something and tore. Can anyone recommend a good adhesive to put it back together? I'd rather not replace the whole thing unless I absolutely have to.
Old Feb 29, 2016 | 04:29 PM
does195's Avatar
does195 is infamous around these parts
Super glue?
Old Feb 29, 2016 | 04:56 PM
mad_max's Avatar
Originally Posted by does195
Super glue?
There isn't really enough surface for superglue to stick. I might have to do something like a plastic 'weld'.
Old Feb 29, 2016 | 06:04 PM
CSK 991 C4S's Avatar
CSK 991 C4S is infamous around these parts
Could drill some small holes and stitch it back together with some zip ties along with some epoxy type glue.
Did you happen to price a new wheel liner?
Old Feb 29, 2016 | 07:31 PM
mad_max's Avatar
Originally Posted by CSK 991 C4S
Could drill some small holes and stitch it back together with some zip ties along with some epoxy type glue. Did you happen to price a new wheel liner?
Good idea. Dealer quoted about $280 (part only) for the new liner.
Old Feb 29, 2016 | 08:14 PM
BradB's Avatar
BradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to all
I did almost the exact same fix on my Cayman a couple years ago. You can easily gain access to the inside without completely removing the liner. I found some scrap plastic and glued it to the backside of the tear (rough up both surfaces to maximize bond) with two-part epoxy (hardware store). The fix is invisible. Total repair time not including the drying time was less than an hour. It's still holding!
yvesvidal
Apr 4, 2016 08:09 AM
L.A.P.
Mar 27, 2016 09:20 AM
Trauma
Feb 4, 2016 06:21 AM
007JB
Feb 3, 2016 05:30 PM
TURBO ELECTRO
Feb 1, 2016 09:45 PM
