More Power
Old May 6, 2017 | 04:23 PM
msgm1's Avatar
msgm1 is infamous around these parts
More Power
Is there anything to do to get more power out of a 991s?
Apart from adding the x51 power kit?
Old May 7, 2017 | 02:25 AM
PorscheCrazy's Avatar
Try Cobb Tuning Accessport
Old May 7, 2017 | 06:51 AM
combatninja's Avatar
combatninja is infamous around these parts
IPD intake plenum and a quality custom tune. 2/3 of the power of the X51 at a fifth of the price.
Old May 7, 2017 | 09:08 AM
msgm1's Avatar
Have you done it?
Old May 7, 2017 | 03:26 PM
I have not but it would be apples to oranges as I have a 3.4L car. The IPD plenum is pretty much the same concept as what Porsche includes in the X51 kit. With a good tune to get the most out of it, you should see gains of around 25-30 wheel horsepower. Remember that the X51 kit advertises crank power numbers so is actually closer to 40 at the wheels. The plenum is about $1000 and a good dyno tune will be about that as well. So factoring in labor, you'd be looking at $2500 or so all in. X51 would run you at least $15,000 installed unless you could find used parts but I don't even know how viable that is as I'm sure it has specific factory programming that is doubtless tied to the VIN. Will you realistically be able to feel a 7 to 9% increase in power? Probably not but nobody realistically needs a Porsche either but here we all are.
Old May 7, 2017 | 04:20 PM
msgm1's Avatar
Lol
Very true!
Old May 9, 2017 | 06:03 PM
chance6's Avatar
chance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to behold
I can tell you I definitely feel the extra 30 hp at the higher RPM end in my GTS. It's not just intake benefit. It's software, intake, different cams, and a little extra valve lift.
The intake is about 1/2 of the equation.
Old May 9, 2017 | 06:04 PM
chance6's Avatar
I also had a Porsche tech tell me that the IPD plenum is a great way to see power gains. I think you'd get the most benefit here on an S model.
Old May 9, 2017 | 10:06 PM
eldertec's Avatar
eldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to behold
13 4S currently
I test drove a Turbo S, scared the heck outta me, can't imagine wanting more power from mine, I mean I can't handle the current power as is
Old May 10, 2017 | 05:27 AM
Jersey Shore's Avatar
Jersey Shore is a splendid one to beholdJersey Shore is a splendid one to beholdJersey Shore is a splendid one to beholdJersey Shore is a splendid one to beholdJersey Shore is a splendid one to beholdJersey Shore is a splendid one to beholdJersey Shore is a splendid one to beholdJersey Shore is a splendid one to behold
Exhaust, IPD plenum, Cobb AP. I have 2 of 3 done and it is noticeable. Learn to drive the car in the upper ranges when you want more power. That is where it is.
Old May 10, 2017 | 09:14 AM
GraSox's Avatar
GraSox is infamous around these parts
Couple questions:
- is the IPD plenum and the GTS plenum the same? Thought I had read the GTS one was different...
- what do they tune when they do a Dyno tune? This type of tune doesn't need a flash?
thanks!
Old May 10, 2017 | 12:00 PM
vividracing's Avatar
A tune is a great way to add some power. We have only dyno tested a base 3.4 in house but even that had a gain of 21 WHP
Old May 10, 2017 | 09:15 PM
chance6's Avatar
Originally Posted by GraSox
Couple questions:
thanks!
IPD vs. GTS are not the same. GTS intake is different. Super smooth intake walls to reduce pressure loss as well.
Old May 12, 2017 | 07:42 PM
Ryane8182's Avatar
Ryane8182 has a spectacular aura aboutRyane8182 has a spectacular aura aboutRyane8182 has a spectacular aura about
Exhaust for sure with cats, plenum, better air intake and tune should get you a nice increase. The vivid tune is a pretty damn good tune. They tuned my 997 turbo when I had that. Definitely felt the tune in that being a turbo an all. Great customer service, very knowledgable and really reliable. Vivid won't steer you wrong. Least my two cents.
