Battery replacement
Old Jun 13, 2017 | 09:22 AM
Poluski's Avatar
Poluski is infamous around these parts
Battery replacement
Has anyone on this forum replaced their own battery with a non-Porsche battery? The dealer wants $455 and I can get a Duracell AGM for $209. Add my time and hassle it might be a wash at the end. Wondering if there is anything magical about the Porsche battery and the process of replacing it. I know there is a reprogramming step which the dealer does when a new battery is put it. thx.
Old Jun 13, 2017 | 02:32 PM
mikeva's Avatar
mikeva is infamous around these partsmikeva is infamous around these parts
you are going to get a wide range of answers to this based on past post -- those that think the Porsche battery and installation tasks are a giant waste of money and time and those that think that having the dealer do the reprogramming is worth it.
Me, I've decide to go with the dealer install based on my readings and subsequent understanding/belief that the reprogramming does extend the life of the new battery. And once I "sign up" for the dealer doing the reprogramming anyway on a battery I put in, it just makes sense to me to have them do the whole job. Mine is going to be part of a 4 year service and a new tire install --- so I'm taking out a 2nd mortgage on the house anyway
Old Jun 13, 2017 | 04:21 PM
does195's Avatar
does195 is infamous around these parts
Install yourself and let the dealer reprogram it
Old Jun 13, 2017 | 09:10 PM
eldertec's Avatar
eldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to behold
Reprogram?
First I've heard of this?
Old Jun 14, 2017 | 05:17 AM
does195's Avatar
Originally Posted by eldertec
Reprogram?
The car needs to be reprogrammed for the new battery. Without, the computer thinks it still has the old battery and may overcharge the new one.
Old Jun 14, 2017 | 04:24 PM
rnl's Avatar
rnl
rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !
I have the Duracell. it's great. no reprograming as you just hook up a 12v to the leads during the battery switch.
this battery does not drop voltage as low as the stock did from the very beginning..I replaced it after 5 years.
Old Jun 14, 2017 | 04:25 PM
rnl's Avatar
rnl
I called Porsche on this as I wasn't about to pay $500 for a stinking battery...they said none needed.
Old Jun 14, 2017 | 04:28 PM
Forujames's Avatar
Forujames is a name known to allForujames is a name known to allForujames is a name known to allForujames is a name known to allForujames is a name known to allForujames is a name known to all
My owners manual has the steps to follow for this "reprograming".
Old Jun 14, 2017 | 05:43 PM
does195's Avatar
The battery is subject to normal wear: its service life depends heavily on the care you give it, climatic conditions and the conditions of use (distances, loads).
It is not possible to use the details on the battery case to determine a comparable battery that meets all the specific requirements of Porsche.
Have the battery removed and installed only by your authorized Porsche dealer.
Only use an original Porsche battery, with the correct part number, as a replacement. Only this battery meets the specific requirements of the vehicle.
After you install a new battery, it must be initialised in the control unit.
Please contact your authorized Porsche dealer.
Please observe the disposal instructions for batteries.
Old Jun 14, 2017 | 06:20 PM
rnl's Avatar
rnl
You can also have the air changed in the tires while you wait it will have the same consequence....the original Porsche battery is not really very good and Porsche sources batteries from different manufactures throughout the model run.
I'm 5000 miles post battery change...it starts, charges, and drops to the nominal voltage level like before...you want to drop $500 on a $200 battery, make sure they wash the car
Old Jun 14, 2017 | 06:27 PM
does195's Avatar
^^^ and this is why I only check this thread monthly. Rennlist
Old Jun 14, 2017 | 06:28 PM
John McLane's Avatar
John McLane is a splendid one to beholdJohn McLane is a splendid one to beholdJohn McLane is a splendid one to beholdJohn McLane is a splendid one to beholdJohn McLane is a splendid one to beholdJohn McLane is a splendid one to beholdJohn McLane is a splendid one to behold
But it's got electrolytes...
Porsche branded tire air costs triple. N-rated air...
Old Jun 14, 2017 | 07:00 PM
rnl's Avatar
rnl
Too funny. I've really not posted in about a year. See everyone next year
Old Jun 15, 2017 | 02:56 PM
ChuckJ's Avatar
ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !
I replaced mine with a Batteries Plus one a year ago and it's been working and charging well.
ChuckJ
Old Jun 21, 2017 | 05:20 PM
Poluski's Avatar
Well I've decided to bit the bullet and ended up with a Porsche battery. In the end it was a ~$230 difference in the total price tag. One thing I've noticed right away with the new battery is that the charging voltage is much lower. 13.2V with new vs. 14.5V on the old battery. In addition the automatic start/stop feature is working more frequently.
