Brake fluid recommendation?
Old Jun 19, 2017 | 02:16 PM
stealthboy's Avatar
stealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud of
I need to flush my brake fluid, and I don't really want to spend the $58 per liter my dealer is charging for factory fluid. Anyone have any recommendations on DOT 4 fluid? No track days yet on this car, so not worried about that.
Old Jun 19, 2017 | 04:19 PM
mtony's Avatar
mtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond repute
ATE Typ 200
Old Jun 28, 2017 | 09:35 PM
991carreradriver's Avatar
991carreradriver has a spectacular aura about991carreradriver has a spectacular aura about991carreradriver has a spectacular aura about
Motul 600
Old Jul 3, 2017 | 10:41 AM
Gr8ful1's Avatar
Gr8ful1 is infamous around these parts
How much is required to flush the system. I'm coming up on 2 years in September when my C2S was built. Time for a fliud change. I'm going with Motul 600 but how much should get.
Old Jul 3, 2017 | 10:42 AM
HG Performance's Avatar
HG Performance is a name known to allHG Performance is a name known to allHG Performance is a name known to allHG Performance is a name known to allHG Performance is a name known to allHG Performance is a name known to all
Motul RBF600 is great stuff for street or light/medium track duty. It's typically available online for about $17-18 per half liter.
Old Jul 3, 2017 | 11:10 AM
2 half liter bottles should be enough. If its your first time, you want want a third on hand until you get the hang of it.
If I may make a suggestion, you might want to consider purchasing a brake fluid tester for around $12. It will measure the moisture content in your brake fluid, which is the real measure of when it should be flushed. Spirited driving or track use will dictate a more frequent change.
Amazon sells them. The link will not work due to the forum block.
Old Jul 3, 2017 | 12:02 PM
stealthboy's Avatar
I used a liter.
Old Jul 3, 2017 | 01:53 PM
Gr8ful1's Avatar
Thanks great suggestion on a tester. The car is not a DD and it only has 2600 miles on it. It was delivered to me new 1 year ago, heck its never been touch by water, top or underneath. My M6 required a brake fluid change every 2 years. I know BMW and VW are serious about changing it regularly.I assumed the same for Pcars.
Old Jul 3, 2017 | 05:37 PM
Feh's Avatar
Feh
Feh is infamous around these parts
Any recommendations for a good vacuum pump for doing fluid changes?
Old Jul 4, 2017 | 06:27 AM
Motive Brake Bleeder.
Old Jul 12, 2017 | 11:42 AM
BradB's Avatar
BradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to all
+1 On the Motive Bleeder. And if you are not tracking then suggest the ATE 200 over the Motul 600. ATE is half the price and less hygroscopic than Motul. Motul has a higher temp rating and is better for track, however.
Old Jul 12, 2017 | 01:37 PM
mtony's Avatar
Agree with Brad! For a street driven car, Motul is overkill and will require more frequent flushes due to its more hygroscopic property. ATE Typ 200 is more than enough for most street driven performance cars and is possibly what comes with the car from the factory.
Old Jul 12, 2017 | 02:01 PM
I have used both the Motul 600 and the ATE Type 200 at different times of the year. Motul for the summer track season and the ATE for the off season. I find the ATE to be pedal soft in comparison to the Motul, however I agree that the ATE is plenty sufficient for street use.
Old Jul 12, 2017 | 03:34 PM
PSI NRG's Avatar
PSI NRG is infamous around these parts
Can't go wrong with the ATE typ 200 or Super DOT4 in a street car.
Power bleeders are awesome, I used to dread changing brake fluid due to the bleeding process. Ever since I got a power bleeder it takes no time and the brakes feel great after every time.
Old Jul 14, 2017 | 07:03 AM
stealthboy's Avatar
I went with the ATE typ 200, and I already had a Motive bleeder that I used. Very easy job. I was surprised at how many bubbles came out with the initial bleed valve opening. My brakes feel much better now!
