993 Last generation normally aspirated aircooled Porsche 911. Community includes the C2, C2s, C4, Targa, C4s and cabriolet discussion.
993 won't idle
Old Dec 19, 2024 | 11:12 AM
ob_1's Avatar
ob_1 is infamous around these parts
993 won't idle
I have a 1995 993, so no SAI. I was trying to go through and get this to pass CA smog. The low speed HC were a little high. So, I took off and cleaned the Idle control valve with carb and choke cleaner inside of it and electric contact spray on the contacts on both it and the plug where it connects to. Checked the ISV electronically off and on the car and it seemed to work fine. Next, I removed and cleaned the air sensor in the intake with sensor cleaner and the contacts with contact cleaner. Next I removed the MAF and cleaned it with MAF cleaner and cleaned the contacts with electric contact cleaner. Put it all together so I could raise the car to change out the Oxygen sensor. Low and behold, it wouldn't start. Finally I gave it a little extra gas and it started. It will idle down to about 1000 rpm but as soon as I let my foot off the gas, it dies. Any ideas?
Also, prior to all this work, I changed out the plugs, rotors and caps, spark plug wires, air and fuel filters, etc and I was driving it around fine. Just couldn't pass CA smog so I did the previously mentioned work.
Thanks in advance
Old Jan 25, 2025 | 02:13 PM
Beta Steve's Avatar
Beta Steve is infamous around these parts
ISV? You mean ICV or? If indeed we’re talking idle control valve, and you cleaned it, I’d double check everything to do with it as they’re a bit of a ***** to get reinstalled correctly. If you have access to a known good one, try it, or replace the one you have. I’m not on this or any 993 forum much anymore but rennlist is by far the best attended forum for the 993.
Old Jan 28, 2025 | 03:55 PM
ob_1's Avatar
Yep, you are correct. I meant the ICV. A mechanic friend of mine told me to drive it around for a couple of weeks to reset the values and computer. It seems to have worked. For the idle anyway. Just failed CA smog this morning. Love the car but this is Very frustrating. And time consuming. I even got the package from Durametric and checked everything. However the codes and values on their software does not correlate to Porsche's codes in the workshop 993 manual. And when I contacted durametric directly about that, they said they couldn't help with interpreting the values or codes. I was on my own. Should of saved the hundreds of dollars it cost for the software and cables.
Thanks for the advice to check out rennlist. I had been on it for BMW stuff but I may have to mosey on over to the Porsche side of things.
Thanks for everything Beta Steve!
Old Feb 24, 2025 | 06:58 AM
ob_1's Avatar
Originally Posted by speedheur
A faulty temperature sensor can cause starting and rough idling problems. If this sensor gives a bad reading, the ECU can send an incorrect signal to the fuel injection and ignition.
So, how can I check the temperature sensor? ohmmeter or voltage or....?
Thanks in advance speedheur
Old Feb 24, 2025 | 08:32 AM
kilog's Avatar
5 Year Member
kilog is infamous around these parts
Since it started right after you cleaned those sensors, I'd double-check all the connections to the MAF and air sensor. Make sure they're snug and clean.
ob_1
993
Sep 5, 2021 06:48 PM
Julien_co
Oct 23, 2016 08:23 PM
thor7000
Cayenne 955/957
May 30, 2013 08:27 PM
sandyclinic
993 Turbo
Aug 22, 2010 02:44 PM
KPV
Aug 5, 2005 03:30 PM
