The Greddy Boost Controller question?
Old Oct 14, 2007 | 11:28 AM
colorinc's Avatar
colorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond repute
The boost control valve has 3 inputs for COM, NO and NC we only have 2 nipples in the package that are screwed into the COM and NC ports. Do we need another one for the NO port and if so where can we get one?
Old Oct 14, 2007 | 01:12 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
Colorinc,
Here are the instructions I received from TK:
Greddy Profec B Spec II install in 996tt
Disconnect the factory vacuum lines from the wastegate solenoid.
Connect the NO port to the port off of the Y-Pipe just outside of the throttle body.
The COM port should go to the line that runs up over the manifold and T's off to the w/g actuators.
The NC port should go to the line that runs towards the drivers side of the car, then to the rubber pipe that holds the diverter valves.
Be sure that all the little red plugs are out of the solenoid!
Tee off the fuel pressure regulator vacuum line and route the hose along with the w/g controller harness.
Route the wiring harness forwards, just to the left of the oil tank, tie wrap the harness to the factory hose routings along the way.
In the tunnel, just in front of the grommet that the shifter/ebrake cables go through, there's a 1" diameter grommet.
You can route the harness up through there.
We typically place the controller in the center compartment where your right elbow would go, leaving about 14-16" of cable to pull
it out and adjust it, then put it away when done. But you can mount it where ever you'd like.
The hot/ground for the w/g controller can be taken from the power window switches. In the 2001 models, the ground is a Brown wire
on Pin A3 of the window switch and the key on hot is Brown/Green/Black and goes to pin A4. Be sure these are 12v and ground, we've found
a lot of discontinuities in the cars.
Then, driving the car, with the w/g controller either all the way down, or off, it should regulate at the spring pressure of your
actuators, or about .4->.5 bar, .7->.8 with upgraded actuators..
From there, turn it up 5% at a time till you get the boost you're after in low, then repeat this in high.
The factory gains, etc. are good for starters. You can tune the controller for slightly quicker boost response by increasing the
gain until it spikes the boost a little bit, then turn it back down till it does not do that. You can do the same thing with the START BOOST setting.
Old Oct 14, 2007 | 01:19 PM
no leave the 3rd alone.... make sure the plastic cover is off of it.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 10, 2014 | 11:59 PM
G911's Avatar
G911 is a glorious beacon of lightG911 is a glorious beacon of lightG911 is a glorious beacon of lightG911 is a glorious beacon of lightG911 is a glorious beacon of lightG911 is a glorious beacon of light
for 997tt its same connection?
Jul 29, 2019 11:13 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
orbelo
Aug 30, 2015 12:26 PM
TrackOne
Aug 20, 2015 12:56 PM
