Rear Windshield Wiper Delete?
Old May 18, 2004 | 10:47 PM
Greyghost's Avatar
Greyghost is infamous around these parts
Anyone removed the rear windshield wiper? To me it seems like the biggest waste. Please offer suggestions and guidance on removal.
Old May 18, 2004 | 11:06 PM
msindi's Avatar
PM sharkster
Old May 18, 2004 | 11:09 PM
Ormond's Avatar
Ormond is a jewel in the roughOrmond is a jewel in the roughOrmond is a jewel in the rough
Try a drive-through car wash at your favorite gas station. It will be deleted quickly!
Old May 18, 2004 | 11:40 PM
sharkster's Avatar
Hi there, it's really easy and about 12 pounds or so with the motor and wiper... Just pull the tab off of the wiper and there's a bolt. Get inside the car and remove the back panel (it pops out) and that reveals the motor. I think there are 3 bolt maybe four and then the rest just pulls out. Get the plug from Eric and you're set.
Old May 19, 2004 | 12:00 AM
Greyghost's Avatar
Thanks Sharky... I will give it a shot!
Old May 19, 2004 | 12:03 AM
sharkster's Avatar
Go for it man. It looks way better without it too... PM me or something if you get stuck
Old May 19, 2004 | 02:01 AM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
Is the plug from Eric just a pop in, or does it require sealant to prevent water from entering?
Old May 19, 2004 | 03:17 AM
limitup's Avatar
limitup has a spectacular aura aboutlimitup has a spectacular aura about
I was going to ask the exact same question as I'm thinking about doing the same. If it doesn't come with a little rubber grommet or something I think a tiny bit of silicon might be in order?
Old May 19, 2004 | 03:30 AM
Greyghost's Avatar
Eric @ bumperplugs.com says that a tiny bead of silicone seals it up perfectly.
Old May 19, 2004 | 04:20 AM
20C4S's Avatar
ok, we all know plug is the way to go. however, i checked closely that the piece is the same on out TT & the GT2, so can a GT2 piece fit on a TT without modication?
Old May 19, 2004 | 04:26 AM
sharkster's Avatar
I don't see why not. I mean it's the same back panel.. the same motor and same wiper so it's the same hole
Old May 19, 2004 | 04:58 AM
20C4S's Avatar
so it should be better than plug right. at least there is no hole to fill.
Old May 19, 2004 | 08:34 AM
cjv's Avatar
cjv
Moderator
Well for one, I believe the panel is welded in.
Old May 19, 2004 | 11:25 AM
I assume the silicone is applied on the inside of the panel (from inside the car) once the plug is installed?
Old May 19, 2004 | 06:11 PM
Greyghost's Avatar
I believe that Eric's plug is spring loaded or something. As for the location of the silicone... that's a questions for Eric himself... ERIC!!!
