EVOMS Water Cooling Kit
Old Oct 25, 2007 | 09:19 PM
S4corrado996TT's Avatar
S4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really nice
Originally Posted by roadsterdoc
The Garrett CHRA has water cooling as an option on the sleeve bearing turbos and is standard on the bb turbos. The GT28/KKK hybrids have water cooled Garrett CHRAs.
KKK does not have a water cooled option on their turbos, but Kevin (UMW) made a prototype water cooled KKK center housing and posted about it on Rennlist. Water cooling is certainly a good thing but it is not necessary. It provides additional measure of reliability for the turbos and that is all. Has anyone ever heard of a KKK unit going bad? It is a very rare occurrence.
Thanks for your explanation!
Old Oct 25, 2007 | 10:07 PM
MidnighTT's Avatar
MidnighTT is infamous around these parts
I wonder, though, as the hybrid builders cram bigger wheels into KKK castings, and create new larger castings that maintain KKK inlet/outlet locations and sizes, maybe that water cooled center section will become more necessary.
Jeff
Old Oct 26, 2007 | 03:08 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
I think Tial will be producing turbos that are not casted but made out of stainless steel? They would be smaller and vent of more heat? Does anyone know?
R
Old Oct 27, 2007 | 12:26 PM
roadsterdoc's Avatar
Member
roadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to behold
R
I doubt it. SS is less heat tolerant than cast iron. Cast iron has been the standard across all turbo manufacturers due to its resiliance.
Old Oct 27, 2007 | 12:57 PM
robmd99's Avatar
Old Oct 27, 2007 | 01:07 PM
Sker66's Avatar
Sker66 is a glorious beacon of lightSker66 is a glorious beacon of lightSker66 is a glorious beacon of lightSker66 is a glorious beacon of lightSker66 is a glorious beacon of light
Tial produces a direct bolt in replacement for the factory turbos but does not state if these are the stainless housings.The stainless housings are used in conjunction with the Garrett Compressor,bearing cartridge assembly, etc. and are cast with a much thinner wall thickness as the SS alloy casting can take more heat in that configuration.Yhey are quite nice!
I have sent a request for more info from there tech line.I'll keep you posted..........gman
http://www.tialsport.com/prod_tc_tial_a.htm
Old Oct 27, 2007 | 05:14 PM
Member
Well I stand corrected. They are casted though, not machined.
Jul 29, 2019 11:13 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
