runnin lean ????
Old Oct 27, 2007 | 08:07 AM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
Awesome, best of luck to you and my ol buddy Jack. Can't wait to see the thread titled: "Help, car making knocking sound and oil all over the floor, but tailpipes are black?!?"
Seriously though, technology has moved on since the 60's bud - get yourself a AFR or EGT please...
Old Oct 27, 2007 | 09:13 AM
oak's Avatar
oak
normal.
Old Oct 27, 2007 | 08:37 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
jimmer have never wished anyone bad luck . you must be a very sad person to resort to that sort of thing.. life is a wonderul thing enjoy it .. do not wast it with unkind words...
Old Oct 27, 2007 | 08:40 PM
am glade to see it's still in the books and that you looked it up wasn't that a land speed record????i just can't remember it was so long ago...........
Old Oct 27, 2007 | 08:51 PM
jimmer23's Avatar
Jeez, I would NEVER wish anyone bad luck especially with these cars. I don't remember where I "wished" that at all - that was sarcasm buddy. I'm just saying that why go out and buy a mega-$$$ car and mod it and not throw in a hundred or two bucks for a proper AFR gauge? Sorry, it just doesn't make any sense to me.
I wish you the best man, but when you're playing with expensive motors and more boost you owe it to yourself to monitor it correctly and not with backyard-mechanic logic like looking at the color of your tailpipes. That's all. GL.
Old Oct 27, 2007 | 09:05 PM
thanks or the reply i trusted that giac sent n me the correct file.. have run this set up for almost two years with no probs... but am buying afr kit thanks again..
Old Oct 27, 2007 | 09:40 PM
landjet's Avatar
Dumb question time--Why would you run leaded fuel in a car designed to run on unleaded? Sorry, I had to ask.
Old Oct 27, 2007 | 10:00 PM
leaded is ez to get at oct of 104 and 110 .unleaded is hard to Find at the pump in ca
Old Oct 28, 2007 | 10:22 AM
killerbee's Avatar
killerbee is infamous around these parts
I will slowly kill the O2 sensors (50 hours) and it also coats the surface of the catalyst (effectively killing it). Possibly the car is running open loop w/o cats otherwise I do not see why one would do it.
Old Oct 28, 2007 | 11:28 AM
oak's Avatar
oak
some tuners offer a racing ecu and/or programs designed to run with out cats and higher oct.
Old Oct 28, 2007 | 02:10 PM
Sker66's Avatar
Sker66 is a glorious beacon of lightSker66 is a glorious beacon of lightSker66 is a glorious beacon of lightSker66 is a glorious beacon of lightSker66 is a glorious beacon of light
Are there any other quality AFR's that also offer datalogging as a comparison to the Zeitronix?
How would i monitor each bank of cylinders?
Is it necesary to weld in an additional bung and seperate O2 sensor for this?
thanks.........Gman
Old Oct 28, 2007 | 06:32 PM
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
thanks.........Gman
yes, you would have to buy an additional wideband sensor and install a switch to toggle between them. i have the egt on one side and the afr on the other side. between the two i can tell if something is amiss.
i'm sure there are other units besides the zeitronix that offer the same features, but i'm also sure they would cost a lot more money the Z is a great unit that offers a ton of features and takes up very little dash space.
Old Oct 28, 2007 | 07:16 PM
Sker66's Avatar
Cool!........Thanks Dog!!
Old Oct 28, 2007 | 07:21 PM
dog how big ? will it it in the battwing?
Old Oct 28, 2007 | 07:48 PM
no. it's too big for the batwing. i have a very simple install. you could do something much more elaborate. i have heard of people taking the display out of the unit and flush mounting in behind the hole cover that mine is attached to. that would look pretty cool in carbon. the only trick would be to find a way to move the toggle button on the side of the unit to the front on the custom plate. you can mount the brain anywhere you want. mine is somewhere in back. the datalogger plug is inside the armrest storage. you can actually run the unit with the just the brain and no display if you want to. you would have to have the laptop plugged in to see and record the data though.
