Oil consumption question....
Old May 20, 2004 | 12:20 PM
RacerX's Avatar
RacerX is infamous around these parts
i have a 01 tt and have the stage 4gt package . I am using 0w40 mobil syn.....im getting roughly 300miles to a quart......is this bad and if so what is most likely the problem and what would have to be done to correct this?
thanks
Old May 20, 2004 | 12:41 PM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
That's too high a consumption in my opinion.
Old May 20, 2004 | 12:56 PM
LSM's Avatar
LSM
Senior Member
LSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of light
Re: Oil consumption question....
thanks
Do you do a lot of city driving and short trips. In my 2003 Turbo, I was always in traffic and was only getting about 400 miles/quart. For my 2004 Turbo I have been doing a lot of my break-in on the highway varying engine speed not in stop and go traffic or short trips. Manual actually says to take longer trips during break-in. I was down one quart at 500 miles but think they didn't top off the oil when I first got it. I now have 900 miles and have not refilled yet, I'll keep you posted.
Lou
Old May 20, 2004 | 04:57 PM
jhiller's Avatar
jhiller is infamous around these parts
1K to a quart in normal driving is about the average. 300mile seems a bit too much to me
Jim
Old May 20, 2004 | 09:06 PM
Joe West's Avatar
Joe West is infamous around these parts
I'm running about 1/4 quart per 1000 miles with 13,000 miles on my turbo.
300 per quart is too much... something isn't right.
Rings? Valves? Leak?
I'd start with a compression test if there are not any obvious leaks.
Joe West
Old May 21, 2004 | 12:18 AM
RacerX's Avatar
yes a lot of short trips....hmmm dealer is doing an oil comsumption test on the car where they fill it up and monitor it for themselves....if its this amt (300/qt) what can i expect them to do? anyone have any experience or knowledge of this? thanks
Old May 21, 2004 | 01:58 AM
Rodis's Avatar
Rodis is infamous around these parts
I add 1 quart every 700 -800 miles. Yours seems a little low. Best to have it checked out before your warranty expires.
Old May 21, 2004 | 02:50 AM
RKS's Avatar
RKS
RKS is infamous around these parts
Was getting 300 miles per qt until 1800 miles. Now have 3500 and getting 900 per qt. Dealer is monitoring consumption. Have heard that P has replaced tt engines having continuing high consumption under warranty. Hope this helps. BTW, how many miles are on your engine?
Old May 21, 2004 | 03:02 AM
I can almost double my milage beyween quarts if the majority of the miles are Interstate cruising.
Around town I now average ~1000-1300 miles between quarts, depending on where my right foot spends it's time.
Old May 21, 2004 | 03:04 AM
I believe Porsche considers something like 600 miles/quart to be acceptable consumption.
Old May 21, 2004 | 09:17 AM
fbrick's Avatar
fbrick is infamous around these parts
RacerX - Doc's number is what I see on the PCA tech board for the 996 NA cars. I don't see where a number is shown for the 996 turbos on the PCA turbo board. If you are a PCA member, you might want to ask there. But 1 quart per 300 miles seems excessive - there must be some miles on an '01 by now. But - Stage 4 and do you track it? Careful with that and the dealer/PCNA if you are seeking some relief!
Jim - 1 qt per 1000Km is approximately 1 qt per 600 miles, and is the minimum to meet Porsche specs (at least, so it would appear, for the NA 996 models). The average should be considerably better.
Fred
Old May 21, 2004 | 10:37 AM
DAVE W's Avatar
DAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to behold
Its been my experience that if you fill the oil to the very top indicator line on some cars you get a lot of blowby working itself back into the intake and consumption can seem high. Keeping the oil at the 1/2 line seems to help this condition and level off consuption below this point.
It is also common for the turbo seal to leak exhasperating this condition...
while it is possible that it is a piston ring or valve seal, its much less likely.
Have you had any MAF sensor problems? The oil in the intake will often cause premature failure of the MAF too, so it can be an indicator....
dave w
ECS Tuning - BMW
Sep 22, 2015 08:34 AM
ECS Tuning - BMW
Sep 22, 2015 08:00 AM
ECS Tuning - BMW
Sep 22, 2015 07:49 AM
ECS Tuning - BMW
Sep 22, 2015 07:31 AM
oo7
Sep 10, 2015 08:08 AM
