5 bar fpr
Old Nov 11, 2007 | 09:18 PM
Christian's Avatar
Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !
5 bar fpr
Were/how is this piece/installed? Pics.........
Christian
Old Nov 11, 2007 | 09:41 PM
Onetime's Avatar
Onetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant future
I saw a write up on this a few pages back. There were also pics included. As I recall it's installed somewhere on the top side of the engine. It's an easy install once you get to it.
Old Nov 11, 2007 | 09:59 PM
Christian's Avatar
I guess I am blind, I cannot find it
Christian
Old Nov 11, 2007 | 10:19 PM
DMaffo's Avatar
DMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud of
nothing easy about doign this.... IT IS A ROYAL pain in the butt to do..... tried doin from under.... NO go... but can be done that way.... I did it with removing everythign from up on top...y pipe, air filter case, air pump and intercooler hose..... then you can get to it... getting the clip off and on was a pain too.... once again....patience..and it can be done...but dont think you'll be done in half hour!!!
Old Nov 12, 2007 | 11:54 AM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
Here is a post I made a while back when I was asking the same thing:
http://69.13.120.185/forums/showthre...ht=BAR+INSTALL
Search: "5 bar install"
Old Nov 12, 2007 | 11:57 AM
otherhwhitemeat's Avatar
otherhwhitemeat is infamous around these parts
the o ring in regulator is also usually vulcanized in the fuel rail and is a pain in the *** even after you get the clip out- sometimes they are really in there good and require a fair amount of umph to get out
Old Nov 12, 2007 | 01:44 PM
tone01's Avatar
tone01 is infamous around these parts
would you need to get your ecu retuned for this upgrade
Old Nov 12, 2007 | 03:23 PM
SSMugen's Avatar
SSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond repute
I know at some point on a k24 stage 2 the flow of stock injectors is pretty much maxed out around 5k RPM but as cheap as this mod is would it make any difference on a k16 stage 2?
Old Nov 12, 2007 | 05:20 PM
Adam Bowles's Avatar
Adam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud of
Would a 5 bar FPR make any difference on a stage 4 k16/24 car?
Bobbyfali
Jul 31, 2017 01:28 AM
Polar993
Sep 28, 2015 11:15 AM
gpt817
Sep 8, 2015 10:21 AM
