ruf v giac
Old Aug 20, 2003 | 10:04 PM
  #31
PorschePhd's Avatar
Actually if you take .85 then you come up with 634. Also your conversion is not correct for SAE. The conversion for SAE IS a standard, however based on the correction factor it can be above rated DIN. Several times I have seen the SAE rating higher than DIN when using the corrected numbers.
Old Aug 20, 2003 | 10:34 PM
  #32
cjv's Avatar
cjv
Moderator
Stephen,
The stock turbo is 415 bhp or 410 SAE. To my understanding 640 bhp would equal about 634 SAE HP?
In addition, if you have a conversion factor, you must work from your rwhp as the starting position. If the dyno renders a rwhp number of 539 what "factor" must you apply to obtain flywheel hp. In the Stage IV case it would have to be about 19%. If you took about 84% of 640 then you come very close to the 539.
So you can multiply your dyno reading by 119% or multiply your fwhp reading by approx. 84%. Six of one and a half a dozen of another. You just have to be clear about what you are talking about so everyone is on the same page.
Old Aug 20, 2003 | 10:51 PM
  #33
PorschePhd's Avatar
I thought the same thing. Intresting enough the years of dynos I have found that in hot weather and humid conditions the SAE factor corrected is very similar in in some cases a horsepower or two higher. Weird I know. Days like today...105 60+humidity....yuck. At any rate it is a standard conversion factor on paper...
Old Aug 20, 2003 | 11:35 PM
  #34
Evolution MotorSports's Avatar
Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !
Originally posted by cjv
Dock,
After you responded I had to go back to the EVO website. The Stage IV GT is advertised at 640 hp (flywheel). Their dyno sheets show 539 rwhp. Note this is bhp not SAE. If I multiply 539 times 1.19 I get 641. It seems like 19% is closer. You would also have to deduct approx. another 6 hp to arrive at SAE power. Is there something I am missing?
The way it should be calculated is take the 640 HP and x by .85 (15%) = ???? RWHP
Old Aug 20, 2003 | 11:42 PM
  #35
sharkster's Avatar
Whatever happened to the butt dyno?
Old Aug 21, 2003 | 07:27 AM
  #36
cjv's Avatar
cjv
Moderator
Todd's above reply brings on another good question. Porsche advertise 415 hp (bhp @ flywheel). I have seen several stock Porsche's dyno'ed. One as recently as yesterday. They always produce between 370 and 380 hp.
In light of the above neither the 85 or the 19 makes any sense.
Old Aug 21, 2003 | 09:07 AM
  #37
skaria's Avatar
skaria is infamous around these parts
I guess we should also specify which dyno is used (2 wheel or 4 wheel). I have seen several stock 996TT dyno'd on the Mustang 4 wheel dyno and we all put about ~ 350 HP / ~350 lb ft at the wheels. The difference is quite significant.
Old Aug 21, 2003 | 09:19 AM
  #38
Chad, Just out of curiosity, how did you come up with your power figures of 805HP and 780 TQ?????
Old Aug 21, 2003 | 10:16 AM
  #39
MKW's Avatar
MKW
MKW is infamous around these parts
But Chad, who knows what the REAL ( vs rated ) HP of the stock cars is ?
375 RWHP divided by 415 rated FWHP would imply only a 10 % drivetrain loss - very unlikely . So.., at a more reasonable 15 % drivetrain loss ( 375/ 0.85 ) , the stock base turbo motor is putting out 440 flywheel HP ?
Old Aug 21, 2003 | 10:38 AM
  #40
oak's Avatar
oak
Porsche always seems to underestimate the HP. From the factory the engines are dyoned and any deviations over and under 3% are supposed to be rejected. Atleast from what I've heard.
Old Aug 21, 2003 | 12:09 PM
  #41
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
In the case of Stage IV, the correction factor is 15.7%. Take the 640 FWHP x 15.718% and you get 100.59 Hp drivetrain loss. 640 - 100.59 = 539.4 Hp...which is what the EVO dyno shows.
The FWHP x the correction factor = the horsepower lost through drivetrain losses. Take that loss and subtract it from the FWHP to arrive at RWHP.
Or like Todd (and others) said, multiply the FWHP times 85% (for a 15% loss) and that will give you RWHP.
Old Aug 21, 2003 | 03:13 PM
  #42
cjv's Avatar
cjv
Moderator
Todd,
I multiplied the rear wheel numbers by 1.18.
Is your Stage V still going to be ready by the last week of September? I can't wait to meet you and see the Stage V up here in Northern California.
Old Aug 21, 2003 | 06:00 PM
  #43
grecomfs's Avatar
grecomfs is infamous around these parts
Stephen,
RS Tuning makes a good product, however I do not believe service wise they are in the same league as Ruf/Weissach Performance. I tried to deal with them once regarding a transmission oil cooler for a 996tt. They have no e-mail, don't answer letters and I wasted three phone calls to Germany. Maybe someone else has encountered a better experience.
I have an RS-Tuning X-50 here in the US. It is a fabulous product but dealing with RS was a real excercise in patience and persistence. I will say that any technical problems that arose along the way were addressed by RS very aggressively and very quickly. But Nordstrom they are not.
Old Aug 21, 2003 | 06:51 PM
  #44
KPV's Avatar
KPV
Regarding the hp/loss discussion, my stock TT (except for Europipe Stage 2) had 374 peak horsepower on a Mustang four wheel dyno.
Old Aug 21, 2003 | 10:25 PM
  #45
Todd,
Chad, Since when are you putting down 683 RWHP????
What are the dates and details?
