HELP!!(puting BOSE subs back in)
Old Aug 20, 2003 | 09:09 PM
EM 996 GTS's Avatar
EM 996 GTS is infamous around these parts
I hope this might help.
It took me sometime to figure this one out.
WHen I put back the Bose Sub, there is something stuck inside, most probably in the between area where the metal holder slide in. Yes... it only occurs on ONE of the side( The ECU side). I saw that there is a tiny plastic stuck in there... I might be wrong but, I can't figure out HOW did it get stuck in there?!?!?!
but anyways... I ignored the lil plastic and just modified that metal holder... I was already frustrated ... so then I cut some pieces out until it slide and fit in perfectly to where it suppost to be. Well that solved the problem for me. I hope we have the same case with the BOSE subs..
Good luck,
Endra
Old Aug 20, 2003 | 09:10 PM
EM 996 GTS's Avatar
pic 2
Old Aug 20, 2003 | 09:11 PM
EM 996 GTS's Avatar
last pic... when I put back to where it belongs....
I really hope this will help you...
Old Aug 20, 2003 | 09:14 PM
EM 996 GTS's Avatar
so far this hold perfectly...
just sand-down the area that I cutted-out, so it wont be too sharp.
well, that metal thing shouldn't cost a lot... (well, it doesn't look like it)
this is the only way that I put my Bose Sub back to where it was.....
and this should hold good because, the TORX screw went in perfect and I still have 51% left on the metal thingy....(as in, I only cut of 49% of it) ohh.. and my rear-seats should hold it good too
I still dont know why I have something stuck in there...
Old Aug 21, 2003 | 06:22 AM
AMG-ETR
Guest
Posts: n/a
YOUR CRAZY MAN!!! I did the opposite, I dug away at the plastic inside it to make it fit!!!
Congrats,
Evan
Old Aug 21, 2003 | 10:45 AM
EM 996 GTS's Avatar
Congrats,
Evan
The plastic that got stuck inside, was so deep, its pretty much impossible for me to take it out. and I tried shoving that POS so hard, it still wouldn't fit in properly... so, I gotta cut 'em to make it fit!
Old Aug 21, 2003 | 11:18 AM
KPV's Avatar
KPV
You guys had me rolling on the floor!! I could hear the swearing up here in NJ Evan!!
Old Aug 21, 2003 | 11:20 AM
msindi's Avatar
Guys - I do not know what you are doing wrong...I took the sub-box out twice and returned it with no problems aor any modifications needed...wierd??
Old Aug 21, 2003 | 12:40 PM
EM 996 GTS's Avatar
Lucky You!
Old Aug 21, 2003 | 05:18 PM
AMG-ETR
Guest
Posts: n/a
YOU JUST HAVE TO RUB IT IN DON"T YA!!!
Yes Ken, if somone wrote what I was screaming all night it would probably look like this :
%$%#%^^%%*&^(_*_)*&*()&^*&%$&%%&#%$&$&^%*&%&^$^%&$ #*%^&^%&^*(%&*^%$^%$##%$#%$#%$^%$&^$^% GOT IT!!!! ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ.
HEHE, just put my DV's and airfilters in, car is great, getting it dynoed tom.!!
Evan
97GtsMonster
Nov 17, 2015 12:38 PM
4ocious
Sep 13, 2015 05:00 PM
Money2536
Sep 1, 2015 04:56 AM
Steven997TT
Aug 27, 2015 02:56 PM
