Window will not go up?
Every time I put the passenger window up (on automatic) it goes up all the way, but once it closes, it opens up again (in the same way it would if it closed on your fingers)... is there a quick fix, or do I have to bring it to the dealership?
Thnaks
Thnaks
Try this:
Open the door.
Remove the negative battery cable.
Wait 10 minutes.
Reinstall the negative battery cable.
Close the door.
I've noticed that, after removing the battery cable... the windows "recalibrate" themselves.
Just a guess... but it may work for you.
Another thought is that this is something which can be calibrated by using a PST2.
Kind Regards,
Joe West
Open the door.
Wait 10 minutes.
Close the door.
Kind Regards,
Joe West
Thanks... I will try that... what I might be thinking is that something is blocking the window... so when it hits the thing thats blocking it... it goes back down
Originally posted by Joe West
Try this:
Open the door.
Wait 10 minutes.
Close the door.
Kind Regards,
Joe West
Try this:
Open the door.
Wait 10 minutes.
Close the door.
Kind Regards,
Joe West
will removing the battery for 10 minutes do anything else to my car... will I have to do anything else when I re-connect the battery?
I've never had to enter a code after disconnecting the battery... perhaps vehicles with the factory nav system are different?
Originally posted by cjv
Yes, you will have to re enter your code back in. Very easy to do.
