New Codes
Old Dec 17, 2007 | 11:31 PM
goldish color floating around( or darker brown)... it really should be clean..... u should not see anything like that.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Dec 17, 2007 | 11:32 PM
killerbee's Avatar
killerbee is infamous around these parts
For what it is worth:
TWC stands for three way converter. The three-way catalytic converter (TWC) reduces emissions of hydrocarbons (HC), carbon monoxide (CO), and oxides of nitrogen (NOx). The codes typically refer to a missfire. However, since you are running cat-less then I gather that the some portion of the ECUs coding has been disabled ?
Old Dec 17, 2007 | 11:34 PM
I personally do not think 101 is good enough for 1.5 bars.... specially with lots of power.
that goes for any car.
Unfortunately only ur tuner can tell you if 101 is Ok at 1.5 bars.
9.66
click to view
Old Dec 17, 2007 | 11:36 PM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
Mark the coolant is green but there was a dark grey mushy buildup on the cap?
Old Dec 17, 2007 | 11:43 PM
jags911tt's Avatar
Anything like what?
Old Dec 17, 2007 | 11:49 PM
jags911tt's Avatar
Mark,
would detonation lead to these codes?
Old Dec 18, 2007 | 01:10 AM
No ur fine...
I don't think the codes have anything to do with ur situation.
run the car at 1.2 bars to see if u can duplicate the problem.... does it loose power? stutter? or just makes the noise?
9.66
click to view
Old Dec 18, 2007 | 06:18 AM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Originally Posted by jags911tt
What exactly is a valve lift?
What is a TWC?
Jags, TWC is referring to the Catalytic. You do not want a valve lift fault. I just checked my service manual and that code POSSIBLY refers to a faulty 2 stage lift. Porsche recommends the car be road tested with 2 service techs. One riding shotgun with a PST2 that can force the valve lift change and they log the results. The tappets arent expensive, about 70$ each , but the head needs to be removed to do it. Here is what the 2 stage valve lift look like https://www.6speedonline.com/forums/...d.php?t=110361 It is the second animation where the valve extends farther with a larger lift.....
Old Dec 18, 2007 | 07:10 AM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
Originally Posted by joetwint
I had catless exhaust.....no codes but had bungs to raise the o2 sensors out of the exhaust
Joe,
Did you do that for all 4? My car is back in the shop but as I recall the 2 wide-band sensors are upsrtream of the first set of cats, so why did you bung them? I understand about the other 2 BC they come after the first set.
Old Dec 18, 2007 | 07:37 AM
KPG's Avatar
KPG
Jags, that is not a very encouraging sign. Hopefully that is just residue from the last time the head gasket failed. Typically you do not want to see any milky, foamy, frothy residue on the cap underside since it can be coolant mixing with oil and then burning off and condensing under the cap....
Old Dec 18, 2007 | 09:34 AM
jags911tt's Avatar
No ur fine...
**** got up this morning and its raining Its virtually impossible to got WOT in 2nd or 3rd with rain in this car.
When it dries up I will set the car to pump program and see if I can duplicate.
Mark I think it does loose power and stutter a little.
Is the sound of detonation that loud? I had my windows up and music playing. My exhaust is loud and I heard those sounds
Old Dec 18, 2007 | 09:35 AM
jags911tt's Avatar
I hope that is from the last time. I will talk with my builder today to see if he cleaned the cap off before I got the car back.
Thanks guys for the help
Jag
Old Dec 18, 2007 | 09:54 AM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
Originally Posted by Al Norton
Joe,
Only the second set (after the cats).
Old Dec 18, 2007 | 09:58 AM
joetwint's Avatar
Jags,do not run the car hard .......what you are hearing is very possibly detonation......get the car back to the tuner and have them check it out........do not run it hard.
Old Dec 18, 2007 | 10:02 AM
joetwint's Avatar
Yes it can be heard inside the car .....I have a old truck that pings under load sometimes and it can be heard no matter how loud you make the radio.Do not run it hard until you get it to your tuner.
