New Codes
Old Dec 17, 2007 | 09:34 PM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
New Codes
Hey all
I was out driving my car today and I went WOT in 2nd and 3rd and I could here some loud ticking sounds (hard to describe the sound) towards 5500 - 6600 rpms. The car drove fine and pulled hard. No CELS.
This got me curious and when I got home I hooked up the duremetric and got:
P0420
Factory Fault Code 40 - TWC conversion, Bank 1
P0430
Factory Fault Code 45 - TWC conversion, Bank 2
Any ideas?
TIA
Jag
Old Dec 17, 2007 | 09:41 PM
jags911tt's Avatar
BTW I have a catless exhaust
Old Dec 17, 2007 | 09:58 PM
wross996TT's Avatar
P0420/0430:
Possible fault cause
♦ Oxygen sensor ahead of and after TWC exchanged
♦ Valve lift fault
♦ Aged oxygen sensor after TWC
♦ TWC faulty
Old Dec 17, 2007 | 10:00 PM
jags911tt's Avatar
Originally Posted by wross996TT
P0420/0430:
♦ Valve lift fault
♦ TWC faulty
What exactly is a valve lift?
What is a TWC?
Old Dec 17, 2007 | 10:01 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
I heard the same sound on mine..
Good luck
R
Old Dec 17, 2007 | 10:02 PM
jags911tt's Avatar
Good luck
R
Are you serious? Did you get the same codes? Was this before you blew the HG?
Old Dec 17, 2007 | 10:15 PM
jags911tt's Avatar
anyone running catless exhaust get these codes?
Old Dec 17, 2007 | 10:21 PM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
I had catless exhaust.....no codes but had bungs to raise the o2 sensors out of the exhaust
Old Dec 17, 2007 | 10:44 PM
jags911tt's Avatar
I did a search here and it seems like the codes are related to the exhaust
. but the sound bothers me. I hope its not detonation
Old Dec 17, 2007 | 10:54 PM
killerbee's Avatar
killerbee is infamous around these parts
Ask Kevin.
Old Dec 17, 2007 | 11:04 PM
what boost were u running?
the cracking/ping type noise is detonation.. check ur plastic coolant to see if u have any junk in there.... like copper residue... and or discoloration..... ( just in case).
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Dec 17, 2007 | 11:18 PM
jags911tt's Avatar
1.5 bar on race fuel
Old Dec 17, 2007 | 11:26 PM
what is race fuel? 100, 104, 110, C16?
did the car jerk between 5500 and 6500? if so its plugs...
u should do the same thing on low boost....
also, if the car leans out it will do funky stuff... get a afr meter on it...
9.66
click to view
Old Dec 17, 2007 | 11:29 PM
jags911tt's Avatar
what does copper residue look like?
Old Dec 17, 2007 | 11:30 PM
jags911tt's Avatar
I have 101 in there right now. The car did not jerk and I had a plug issue before and it doesnt feel like that.
