Coolant Flush Problem
Old Dec 27, 2007 | 03:31 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
Hey guys, I am changing out my coolant and have a problem bleeding the system. I cannot get the T-stat to open up? I filled the tank resevoir, started the car up and brought it up to normal operating temp. I take it up to 215 degrees on my Brockway meter (about 200 on the factory gauge). The fans do kick on. The temp keeps rising and I am worried of overheating. Any ideas?
Old Dec 27, 2007 | 04:21 PM
BigBadBen's Avatar
BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !
The only way to bleed the system without a pressure bleeder as I suggested from Snap-on etc is as follows.
You will need to have one person start the car and hold the RPM at 3500 to 3700 and keep it there contantly, DO NOT LET THE RPM's weaver in anyway shape or form or the valves in the system will close and coolant will shoot out of the fill reservoir. Trust me I know all about this that is why I bought the Snap-on tool. It is very difficult to hold the RPM's at that point as the throttle is difficult to modulate as the engine warms up. You will need to hold the RPM's for about 10 minutes or so as you fill the system with coolant. Holding the RPM will open all the valves.
Cool luck with this as the person filling the system might have the pleasure of warm to hot coolant shoot out all over the place. This is the only other way of bleeding system properly or you will blow off one of the coolant hoses if these is any air lock left in the system. I had this happen to me a few times before I got the Snap-on tool.
BTW, the tool requires a large compressor tank to create the vacuum needed in the coolant system.
Hope that helps,
Ben
Old Dec 27, 2007 | 06:18 PM
dgreen78's Avatar
Thanks ben, wish I knew this ahead of time. Any interest in renting it out for a fee? Pm me...
Old Dec 28, 2007 | 10:00 AM
BigBadBen's Avatar
Your welcome...by the time we ship it back and forth you could buy one. http://buy1.snapon.com/catalog/item....store&tool=all
I bought mine for $150 CDN..I am sure you can pick one up cheaper.
hdc4
Bentley
11
Jan 6, 2019 07:17 AM
bshah1976
Sep 12, 2015 07:37 AM
Blue Chip
Sep 10, 2015 07:07 AM
