pss10 VS pss9
Old Jan 24, 2008 | 11:52 AM
kcphuah's Avatar
kcphuah is infamous around these partskcphuah is infamous around these parts
pss10 VS pss9
About to buy one and saw tirerack has the two for the same price. I am not a track junkie, but precise handling and comfort are my main concerns. Would pss10 be a better buy in comparison?
Ken
Old Jan 24, 2008 | 01:33 PM
Superfly's Avatar
Superfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant future
I think the only difference besides 10 vs 9 adjustments and actual NUMBERS vs clicks for those adjustments, is that the 10's are the current model and the 9's are going to be discontinued. There may be other changes/improvements? that are not as obviously advertised yet (valve rates, spring rates etc). For the same price, I'd buy the 10's. Having said that, with a new model out, you'd think that you should be able to find 9's at least a little bit discounted....and if you can, that might give you some decisions to make.
Pro
Old Jan 24, 2008 | 03:47 PM
DynamicMotoring's Avatar
DynamicMotoring is infamous around these parts
The adjustment has numbers, and it also clicks. Numbers make it much easier to remember settings for sure. Either one is a good choice.
Old Jan 24, 2008 | 08:04 PM
c2mojo's Avatar
c2mojo is infamous around these parts
ummm, why would you get the discontinued model? It's a 5 year old design and the replacement is here
Old Jan 25, 2008 | 03:05 PM
WyattTT's Avatar
WyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud of
Are you able to lower the car more with the 10's then with the 9's?
Josh/AWE
Oct 23, 2015 04:33 PM
ELMEL
Sep 28, 2015 01:12 PM
bongnation
Sep 25, 2015 02:58 PM
JWrightPNH
Sep 14, 2015 01:15 PM
igdawgi
Sep 4, 2015 07:05 PM
