high idle
Old Jan 26, 2008 | 04:44 PM
Onetime's Avatar
Onetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant future
high idle
A few days ago I accelerated hard and after I parked the car and got back in it, it idled high and threw a CEL. Now, it will idle high and occasionally the idle will go back to normal. The code reader says PO507. Any ideas?
Old Jan 26, 2008 | 04:59 PM
Staff@RPM's Avatar
Staff@RPM is infamous around these parts
Hi, i am not at the shop at the moment, ( so i don't have access to the codes) but in the past my 996TT has had similar problems with idle, it turned out to be some vacuum lines that blew off under boost.. Check all lines and listen for hissing..Likewise, on my car the idle went to normal speed with the AC compressor running (added load),, Hope this helps, if still no answer pm me Monday and i will check out the specific code and help you diagnose, TIM
Old Jan 26, 2008 | 05:00 PM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
Clear the code and disconnect the battery. May be MAF, might not.
Old Jan 26, 2008 | 05:02 PM
wross996TT's Avatar
P0507: 32 Idle air control at stop - above limit
Possible fault cause
♦ Throttle is jammed
♦ Leaks in intake air system
Old Jan 26, 2008 | 06:57 PM
Onetime's Avatar
Thanks so much for the info.
Old Jan 26, 2008 | 07:35 PM
tjj7ff's Avatar
tjj7ff is infamous around these parts
I just had the same problem with the same code, P-0507 as well as code P-0102. The primary problem was with the secondary charging system in the alternator, which was putting out a charge but was to weak. When the radiator fans would come on the RPMs would jump from 750 to 1,200 and sometimes drop below 750. After a new alternator was installed it still ran a little ruff. The MAF was changed out and the engine smoothed out.
nlakind
Nov 6, 2015 10:15 AM
03EvoIII
Sep 21, 2015 04:38 PM
turbotuner20v
Sep 11, 2015 12:02 PM
EMC2
Cayenne 955/957
Sep 7, 2015 05:20 PM
