Who Wants to Try a NEW Turbo???
Old Feb 8, 2008 | 09:57 AM
  #91
Originally Posted by vividracing
GTR's are not easy to mod... They are truly a new breed. Yeah you can do a bolt on exhaust, intake... but that factory ECU is so advanced. I was told it knows when you are track racing????
I hear the same... but then look what happened to the P cars... It was supposed to be hard too... LOL
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Feb 8, 2008 | 01:09 PM
  #92
vividracing's Avatar
true!
Old Feb 8, 2008 | 01:14 PM
  #93
gmoney's Avatar
intake mods are throwing all kinds of codes on the new GTR (via Mines). Looks like Nissan was not kidding on making this one tough to crack.
Old Feb 8, 2008 | 01:52 PM
  #94
unvmy996's Avatar
ya i just read that also ...., i also heard that nissan will be quick to void warrantys on modded cars ..... oh well.
Old Feb 8, 2008 | 02:58 PM
  #95
Mitch@Vivid's Avatar
Mitch@Vivid is a jewel in the roughMitch@Vivid is a jewel in the roughMitch@Vivid is a jewel in the roughMitch@Vivid is a jewel in the rough
Must not be too hard cause Mines has a VX-Rom out for them already!!!
Mitch
Old Feb 8, 2008 | 04:00 PM
  #96
Mines... what about Yours.... hahahaha damn so bored. Someone buy something.
Old Feb 8, 2008 | 05:56 PM
  #97
deandob's Avatar
deandob is infamous around these parts
Dan, PM sent for more details about your Vivid setup.
Old Feb 8, 2008 | 06:13 PM
  #98
Got it and replied...
Old Feb 8, 2008 | 11:24 PM
  #99
996Choy's Avatar
996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of
HKS got a setup for R35 that is supposed to make like 570hp already
Old Feb 9, 2008 | 12:51 PM
  #100
fgaillard's Avatar
fgaillard is a glorious beacon of lightfgaillard is a glorious beacon of lightfgaillard is a glorious beacon of lightfgaillard is a glorious beacon of lightfgaillard is a glorious beacon of light
Hello, Planning to upgrade my K24 in 18G, what else do you have on the fuel system, out of your GT2 pump? Going to run Proto Map, any Lines or Injectors? As well, can you tell me some more about your Tial external wastegate, as I plan to run a Profec..Thanks
Old Feb 9, 2008 | 12:58 PM
  #101
u cant run the tials external on KKKs.... forget it.
keep ur headers.. get 20gs if todd will sell u them... ecu, profec, injectors and second fuel pump and a MAF with the housing.. thats it.... trust me. if you want to waste money just donate it to me at least I will have some for Coffee every morning hehe
markski
9.66
click to view
Old Feb 9, 2008 | 01:17 PM
  #102
fgaillard's Avatar
Thank you very much, will send my request to Todd, hope he will sell me his precious 20G...Will keep you updated..cheers, and one day, maybe a coffee...
Old Feb 9, 2008 | 02:34 PM
  #103
deandob's Avatar
More clarifying questions about the K16/16G, if I may
- Are you stuck with a 1.0 bar tune? As the 16G is even more efficient than the K16/24, can the tune be setup for 1.1 bar or even 1.2 bar?
The question about the upgraded wastegate spring was not answered fully. It seems a better wastegate spring would be a benefit, what does it do as the boost is controlled by the ECU?
Also it was mentioned earlier that an upgraded spring will reduce turbo life, why would that be if the turbo is operating under its efficiency curve?
Thanks!
Old Feb 9, 2008 | 02:35 PM
  #104
Yes you can... you can completely. External wastegates setup properly with a Profec B and right tuning will get you an easy 40 extra ft/lbs. I have proven that on stock K16's. By passing the exhaust when the wastegate opens it makes a huge difference.
fgaillard - if you want K24/18G or a promo deal on our 650 kit to show Dubai how it is done, PM me.
Old Feb 9, 2008 | 02:38 PM
  #105
deandob - the aftermarket wastegates allow you to up the boost. The stiffer the spring determines when the wastegate will open. In the Tial wastegates for example, we run a .8bar spring. This means that at .8 bar they open. So we will make .8bar of boost. Now without doing a boost controller, we could get the addition springs to make it 1.0bar. That means the car will make 1.0bar of boost. But with the boost controller, you can control the boost. So if I have .8bar wastegate springs and set my profect to 1.2 bar, I am making 1.2 bar... very straight forward.
On the K16/16G or even the K24/18G, you can run the stock wastegate, then run a boost controller and set it to the boost you want to run. Race gas, run 1.3. Pump gas, be safe and run 1.0bar. You are moving more air so you can make more power with the same boost.
