tire diameter difference
Rating: Thread Rating: 2 votes, 5.00 average.
Old Feb 18, 2008 | 12:36 AM
FlyYellow's Avatar
FlyYellow is infamous around these partsFlyYellow is infamous around these parts
i noticed the new 997 tt comes with the following tires. my question is - how does the car run with the tire diameter differential of 25.5 to 26.3? isn't that too big of a differential?
235/35ZR19
Overall Diameter: 25.5"
Revs/hr 817
305/30ZR19
Overall Diameter: 26.3"
Revs/hr 788
Old Feb 18, 2008 | 04:41 AM
MGS996TT's Avatar
MGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to behold
Good point fly!!
Stock Tire - 235/35R19 >Search Tires Tire 1 - 305/30R19 >Search Tires Section Width:9.25 in235 mmSection Width:12.00 in305 mmRim Diameter:19 in482.6 mmRim Diameter:19 in482.6 mmRim Width Range:8 - 9.5 inRim Width Range:10.5 - 11.5 inOverall Diameter:25.47 in646.93 mmOverall Diameter:26.20 in665.48 mmSidewall Height:3.23 in82.042 mmSidewall Height:3.60 in91.44 mmRadius:12.73 in323.34 mmRadius:13.10 in332.74 mmCircumference:80.01 in2032.2 mmCircumference:82.30 in2090.4 mmRevs per Mile:816.6Revs per Mile:793.8Actual Speed:60 mph100 km/hSpeedometer1:58.3 mph97.2 km/hSpeedometer Difference: -Speedometer Difference: 2.872% too slowDiameter Difference: -Diameter Difference: 2.79%
Old Feb 18, 2008 | 09:17 AM
Joe Weinstein's Avatar
what brand and model are the 997tt tires?
Old Feb 18, 2008 | 11:08 AM
FlyYellow's Avatar
I believe that the are the michellin ps2
Old Feb 18, 2008 | 11:14 AM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
I'd say that if the 997s brain is set up to recognize a 4% differential (or whatever) as normal or reference.......then all would be fine
Old Feb 18, 2008 | 11:20 AM
FlyYellow's Avatar
so can you run that setup on a 996tt???
Old Apr 26, 2008 | 01:47 PM
sid350's Avatar
sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !
I realize ideal for the 996TT is as close to 0% difference as possible but does anyone know what max % allowable diameter difference is? Given the 997TT currently allows 3%.
Old Apr 26, 2008 | 02:02 PM
Turbo Fanatic's Avatar
I'm with Gregg.
PLUS the 997 has an electronic AWD activation mechanism, so no viscous coupling to overheat. Basivcally it's 100% RWD until AWD is engaged.
The 996 Is 99% RWD until AWD is engaged, and even then not much torque makes to the front. Enough to make difference, but you will NEVER get the front tires spinning on a 996 in the dry.
Old Apr 26, 2008 | 02:39 PM
sid350's Avatar
So here's what I want to do... I want to keep my 225/40/18's up front and replace my rear 295/30's with 315/30's I just picked up from "paulycw" today. I calculated %difference and it comes out to be 1.4%. Based on everything I've read this is acceptable. Has anyone done the same?
Old Apr 26, 2008 | 02:54 PM
should be fine. get 235s in front if you can later.
I have a set of 255/35s mounted on stock fronts in the garage that I have never tried for fit. Should really help the understeer.
Old Apr 26, 2008 | 08:10 PM
tom kerr's Avatar
I currently run 265 front and 335's rear on 18's
Old Apr 26, 2008 | 08:20 PM
sid350's Avatar
Ari, well as soon as saw your reply back I got them put on and the 315's look awesome... I drove the car just now to LA and back to Irvine and it feels pretty good no noticeable ride changes. I'll be looking to replace my 225-40's for some 235-40 Pirelli PZero Rosso's to match the rears. %Difference will then be 0.15% per the GT2 setup. Will keep an eye out in the forums and tirerack closeouts.
Old Apr 26, 2008 | 08:23 PM
joyride's Avatar
joyride has a spectacular aura aboutjoyride has a spectacular aura aboutjoyride has a spectacular aura about
Tom did you have to roll your fenders for the front? On what wheels?
Old Apr 26, 2008 | 08:50 PM
sid350's Avatar
Tom, what aspect ratio? I assume 265-40's and 335-30's. Is this correct? That would be a 1.67% difference in tire diameters.
Old Apr 26, 2008 | 10:48 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
The difference in height should be less than 2% from OEM and less then 2% front to rear
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
