Labor cost
Labor cost
How much should it cost for labor when they install a new clutch/flywheel? My shop says that they pull out the entire motor to do it right. They are also replacing the sparkplugs since the the engine is out. Price; 2100.00, sounds high.
OMG you are getting ripped off... the local P car dealer at 160 bucks an hour charges $1800 for the clutch.
2001 996TT 3.6L and stock ECU
OK. 160 an hour and some shops claim it is a 10 to 12 hour job. So it could be anything from 1600 to 1900 dollars. By the way, the car is scheduled to be worked on March 19th. Nothing has happened yet.
ESTIMATE 2002 Porsche GT2
Part Cost Labor Cost
R & R engine & transmission assembly 9.20
Clean parts 1.00
Unflange & flange transmission 1.50
R & R clutch 1.00
Bleed clutch system 1.00
Bleed cooling system 1.00
Clear all faults in ECU from engine R & R 1.00
R & R flywheel, change rear main seal 1.40
Labor total 17.10 hours
$ 2,146.50
AC Recharge (outside labor) $ 180.00
Clutch bolts (9 bolts) $ 33.93
Power steering fluid (1 bottle) $ 30.46
Porsche coolant (2 bottles) $ 129.28
Labor discount $ (196.65)
Parts total193.67
Total Estimated Cost $ 2,143.52
Clean parts 1.00
R & R clutch 1.00
$ 2,146.50
Parts total193.67
Am I missing something here? Where are the actual clutch parts in the quote above? I see everything but the clutch itself. When yuou add that doesn't this almost end up being like $3K? Don't see any plugs on this either (BTW, when I had my 40K service done on my Cayenne, the charge for the plugs was $16 ea...ouch what a rip!)
They do great work and are very thorough and the shop is operating room clean. I trust them with my car, they've worked on it over the last several months without any issues. Luckily, the new estimate came from the tech that is actually doing the work and decides the cost.
