996 turbo boost output; What is normal?
Old Mar 3, 2008 | 09:22 PM
CAA's Avatar
CAA
CAA is a name known to allCAA is a name known to allCAA is a name known to allCAA is a name known to allCAA is a name known to allCAA is a name known to all
What is the normal amount of pressure or range i should expect form my stock turbos on a 2001 996tt. I cannot get past .7.Is this correct or do i have and underlying issue?
CAA
Old Mar 3, 2008 | 09:23 PM
That's correct
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Mar 3, 2008 | 09:34 PM
rwilliamtaylor's Avatar
rwilliamtaylor is a glorious beacon of lightrwilliamtaylor is a glorious beacon of lightrwilliamtaylor is a glorious beacon of lightrwilliamtaylor is a glorious beacon of lightrwilliamtaylor is a glorious beacon of light
.6 - .7 bar on a normal 996TT. (measured in 3rd or 4th gear WOT)
.8 - .9 bar on an X50.
These are steady state numbers, you may occasionaly see higher spikes.
Old Mar 4, 2008 | 05:14 AM
Ray C.'s Avatar
Ray C. is infamous around these parts
0.6-0.7 is perfectly normal. With an ECU flash you can get boost to 1.0-1.1. Enjoy
Old Mar 4, 2008 | 11:45 AM
maxboost's Avatar
maxboost is infamous around these partsmaxboost is infamous around these parts
what can one expect with 996TT 1.1 bar and exhaust on a your typical dyno jet?
yes i understand they vary but general speaking
Old Mar 4, 2008 | 01:27 PM
mmmmm's Avatar
mmmmm is infamous around these parts
Do you see higher boost pressure with lower temps or higher temps?
I think on my X50, I use to see .9 in the summer and now I see .8 bar with colder temps. Does this make sense, or am I overlooking other factors. (same gas, same test road, same 3rd and 4th gear around 4K-6.5K rpm) at WOT.
Old Mar 4, 2008 | 01:35 PM
SpeedYellow's Avatar
SpeedYellow has a spectacular aura aboutSpeedYellow has a spectacular aura aboutSpeedYellow has a spectacular aura about
depends on if the car is warm and of course, there's an octane sensor on these cars so you SHOULD see the car develop peak boost when the CAR is warm, and the air is cold (faster) but again, there are a number of factors that might affect your results. looks normal, though.
the car will not give you full boost if the car isn't thoroughly warmed up and you may also see it limited by poor fuel quality.
gas quality is not the same year round. depending on where you live, and the season, there can be varying degrees of additives that will affect things.
Old Mar 4, 2008 | 02:59 PM
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
I was told 520bhp@crank. Anyone to confirm?
Old Mar 4, 2008 | 03:05 PM
Terminator's Avatar
Should be other way around. All things equal cold air = more boost.
BlackMarketRacing
Dec 8, 2015 01:49 PM
PelicanParts.com
996 Vendor Classifieds
Aug 20, 2015 02:41 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:43 PM
