HELP: 1st gear rpm problem...
Old Mar 4, 2008 | 04:50 PM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
Lately i have been noticing a problem, i appreciate any help you guys can give me
While in 1st gear from 3.5k rpm and higher the rpms seem to stay...
So when im in 1st gear at 3.5k or above when i shift into 2nd, the rpms don't drop while between gears.
I have also noticed today while in 1st at 4k rpm, when i put it into neutral the rpms stay at 4k rpm.
This only happens in 1st gear.
Sachs clutch, pressure plate, LWFW.
SG700 kit.
TIA
Old Mar 4, 2008 | 04:54 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
I have the same thing when I have my 100 octane Revo program set. I was told the increased timing of the race gas file is causing this to occur. The only difference is that my car decreases in RPM (from 4000 to 3000) at a slower rate when in first gear.
Old Mar 4, 2008 | 05:04 PM
robertp, thanks for your input.
My program has not changed. It has started doing this recently.
Old Mar 4, 2008 | 05:17 PM
robertp's Avatar
When I switch back to stock, it does not hold the RPM.
Fadi
Aug 17, 2018 05:16 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
GSP
Sep 9, 2015 05:31 AM
Saint Ari
Sep 4, 2015 03:30 PM
