what are you guys paying for race gas ?
Old Mar 16, 2008 | 08:40 AM
racerjsz's Avatar
racerjsz is a splendid one to beholdracerjsz is a splendid one to beholdracerjsz is a splendid one to beholdracerjsz is a splendid one to beholdracerjsz is a splendid one to beholdracerjsz is a splendid one to beholdracerjsz is a splendid one to beholdracerjsz is a splendid one to behold
100 Octane - google Sunoco Race for locations
In Baltimore $7 gallon.
Little NOTE: IF you are in a state that requires Ethanol added to the fuel the difference between a non-Ethanol and Ethanol fuel is huge. Ethanol has a lower BTU and therefore LESS (edit) potetial power than Gasoline. if your state has 93 with eth. and you put 100 wich doesn't you feel a HUGE difference regardless of your tune. You'll need to run 5 gallons through before your computer takes full advantage. Disconnect the bat for 30 sec for best results.
Old Mar 16, 2008 | 09:39 AM
unvmy996's Avatar
Little NOTE: IF you are in a state that requires Ethanol added to the fuel the difference between a non-Ethanol and Ethanol fuel is huge. Ethanol has a lower BTU and therefore potetial power than Gasoline. if your state has 93 with eth. and you put 100 wich doesn't you feel a HUGE difference regardless of your tune. You'll need to run 5 gallons through before your computer takes full advantage. Disconnect the bat for 30 sec for best results.
let me see if i understand. 93 oct with added ethanol is better then regular 93 without eth ??
and where at in B more can i get 100oct for 7$ ? cuase i live 35 min from b more. its worth it for me to drive there fill up a 10 gallon conatiner and drive back , rather then paying 50 $ for 103 for 5 gallons.......
Old Mar 16, 2008 | 11:25 AM
racerjsz's Avatar
Fuel with Ethanol is WORSE than non-eth fuel.
Here is a sunoc Site locator and great info about fuels. Check for Sunoco 260GT fuel or Cam2GT. be careful with higher octanes as some contain lead - very bad for your cats! Not the kitty's of course.
http://www.sunocoinc.com/site/Consum...istributorMap/
8000 LochRaven Blvd in Towson is where I buy mine.
Old Mar 16, 2008 | 11:26 AM
unvmy996's Avatar
good deal thanks , towson is even closer. do i have to run a cycle through (liek 5 gallons of the 100oct) before the ecu adapts so i crank the boost up? or could i just add teh race gas when my tanks iscompletely empty?
Old Mar 17, 2008 | 02:56 PM
BiGGie Nick's Avatar
BiGGie Nick is infamous around these parts
marksi, where are you getting race gas for chicago at those prices?
Old Mar 17, 2008 | 05:30 PM
RCNJ's Avatar
RCNJ is infamous around these parts
Originally Posted by LT1
That's pretty good. Where in NJ do you get that?
A-1 specialty fuels in Paterson,NJ
Old Mar 17, 2008 | 05:31 PM
Maciej@RPM's Avatar
Maciej@RPM is infamous around these parts
Really? Thought you got it on 46, where's the place in Paterson?
Old Mar 17, 2008 | 05:52 PM
Ice's 996tt Cab's Avatar
Ice's 996tt Cab has a spectacular aura aboutIce's 996tt Cab has a spectacular aura aboutIce's 996tt Cab has a spectacular aura about
Agoura Hills, Ca.
I paid $7.00 a gallon for 100 at the pump.
Ice
Old Mar 17, 2008 | 05:56 PM
Correction. $6.00 Great Value considering Preminum 91 in Malibu is $4.69
LOL, What a joke!!!!!!!
Old Mar 17, 2008 | 10:41 PM
vividracing's Avatar
i just filled up with 100oct for $6.49/gallon.
Jul 29, 2019 11:13 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
gulf gt
Aug 27, 2015 10:27 AM
Lucid Moment
Aug 20, 2015 02:22 PM
