How can I keep the rear wing up?
Old Jul 2, 2004 | 01:55 AM
996turbo's Avatar
996turbo is infamous around these parts
I rather have the wing on the "up" position all the time. Is there a fuse that will disable it from going back down? Thanks
Old Jul 2, 2004 | 02:05 AM
BCS996TT's Avatar
BCS996TT is infamous around these parts
Re: How can I keep the rear wing up?
If you take off the inner decklid cover, you will see the wing motor which rests just above the cooling fan.
Simply pull the black and red wires off and you will be set. You will get a rear wing fault code...but that's it.
Very easy to do.
Old Jul 2, 2004 | 02:11 AM
996turbo's Avatar
Sounds easy enough...Will the fault code trigger a check light in the dash??
Old Jul 2, 2004 | 02:48 AM
dpj's Avatar
dpj
dpj is infamous around these parts
yes.
Old Jul 2, 2004 | 02:50 AM
OKHJOON190's Avatar
OKHJOON190 is infamous around these parts
i was wondering the exact same thing ... is there a way we can get the dash light off ?
Old Jul 2, 2004 | 02:55 AM
collin996tt's Avatar
Senior Member
collin996tt is infamous around these parts
Keep it on and let it burn out
Old Jul 2, 2004 | 03:42 AM
AeroTT's Avatar
AeroTT is infamous around these parts
Old Jul 2, 2004 | 03:49 AM
HKE46Boy's Avatar
HKE46Boy is just really niceHKE46Boy is just really niceHKE46Boy is just really niceHKE46Boy is just really niceHKE46Boy is just really nice
Old Jul 2, 2004 | 04:22 AM
Gary (Fl)'s Avatar
The Newest "Bling King"
Gary (Fl) is infamous around these parts
There is a way to modify the wiring harness. I don't know exactly how, but when fixed wings are put on Turbos you have to modify the harness to avoid the light being on all the time or get the harness they use with the aero kit. Someone that does these installs can help I'm sure.
Old Jul 2, 2004 | 04:26 AM
AMG ETR's Avatar
If you bridge connector 2 and 5 you will get rid of the light
Evan
Old Jul 2, 2004 | 05:26 AM
996turbo's Avatar
Evan
Evan, are the connections you are talking about under the wing or somewhere else??
Old Jul 2, 2004 | 05:41 AM
AMG ETR's Avatar
If you open the engine lid, they run up the right "shock", its taht wireing harness...
Evan
Old Jul 2, 2004 | 05:51 AM
996turbo's Avatar
Cool...thanks for the info, will try it this weekend.
Old Jul 2, 2004 | 05:52 AM
fasteddiett's Avatar
fasteddiett has a spectacular aura aboutfasteddiett has a spectacular aura about
so, you realize that with the wing up in a parking lot it will take a thief about 30 seconds to steal it with the right tool , right????
SO,,,,,, within about 3 mins you wont have a wing or headlights...
just a friendly warning.
Old Jul 2, 2004 | 06:25 AM
ESK's Avatar
ESK
Hick from NH
ESK is infamous around these parts
How about putting Viagra in the fuel tank? Then again, it may only stay up for a few hours.
Jul 29, 2019 11:13 AM
orbelo
Aug 30, 2015 12:26 PM
undefnd
16
Aug 26, 2015 07:59 PM
