AC is making a strange noise
Old Mar 13, 2008 | 11:15 PM
raidentech's Avatar
raidentech is infamous around these parts
I have a 996TT. When I turn on the AC, the right side around the airbag makes a small click click sound. Like some air is hitting something around that area. Also, it makes that sound when I turn off the AC. Anyone has that problem? The AC is fine, and it's cold. I wonder what's that noise is coming from? Please advise.
Thanks.
Old Mar 14, 2008 | 10:05 AM
smistry007's Avatar
smistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond repute
I had a similar issue- the AC blower/ motor under the glove box area needed to be replaced- simple DIY task
Old Mar 18, 2008 | 04:25 PM
raidentech's Avatar
Do you have DIY instructions?
Thanks.
Old Mar 19, 2008 | 06:45 AM
AIRjordan23's Avatar
AIRjordan23 is infamous around these parts
ill confirm what smistry007 said. its some motor underneath the glove box. had it replaced under warranty. forgot the exact name of the motor. starts with a "C"... lol sorry. took them a couple of hours since they glove box and a few other things need to come off.
Old Mar 19, 2008 | 10:34 AM
smistry007's Avatar
from the Workshop Manual:
1- remove footwell bulkhead and right air guide. Pull off electrical plug connection on the blower motor and remove wire from the holder.
Note- when the housing lid is removed, the blower motor is simultaneously detached from its guide. Hold the blower motor and carefully remove it in the downward direction.
2- Pull off electrical plug connection on the ballast resistor and undo both fastening screws on the housing lid. The ballast resistor and housing lid are a spare part.
Unfortunately, I didn't take pics when I did this and my copy of the workshop manuals is security protected and won't let me copy pics off of it.
If you'd like a printed sheet with the pics/ diagrams, I could mail it to you.
GL
Sameer
docboy
Sep 6, 2015 06:57 AM
jmbmm
Aug 28, 2015 02:01 PM
Senatorblutarsky
Aug 28, 2015 12:44 PM
mlife2878
Aug 26, 2015 07:02 PM
Zero911
Aug 24, 2015 06:51 PM
