Rubbing on hard launch?
Old Apr 5, 2008 | 10:58 AM
996Choy's Avatar
996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of
Hi,
These days I notice that when I do a hard launch, I get rubbing (or at least what sounds like rubbing) at the rear wheels. I have running BBS Re-Mg exact same size as stock. I get it occassionally on turns as well, and a whole lot at track days.
Any guess as to why this could be happening? Suspension dying?
Thanks and cheers
Old Apr 5, 2008 | 11:12 AM
Turbo Fanatic's Avatar
Same size, what offset?
Old Apr 5, 2008 | 11:15 AM
Evader's Avatar
Evader is infamous around these parts
What you are hearing is most likely wheel hop.
Wheel hop is when the traction of your tires is biting at the road surface and the suspension dynamic cannot sustain the pressure to keep the wheel on the road. Thus the wheel "hops" and you get a bouncing sensation accompanied with a tire rubbing noise.
Get an aftermarket suspension and slightly slip your clutch on the launch.....your car will actually be faster this way.
Old Apr 5, 2008 | 09:33 PM
tom kerr's Avatar
if you have stock suspension it is shot. very common for track cars up in years as suspension starts to go and car squats and dives and rolls you will get some rubbing as the amount of suspension travel is abnormal. Believe me I know.
Old Apr 5, 2008 | 09:55 PM
996Choy's Avatar
Same size same offset ... so I am guessing it's probably not the wheel ...
Old Apr 5, 2008 | 09:57 PM
996Choy's Avatar
Thanks guys, it's probably the suspension. Already got a set of JIC waiting to be installed once I find a shop who won't charge me outrageous $$$$.
Rguy
Apr 12, 2020 11:11 PM
Korntera
Sep 15, 2015 08:20 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
su_maverick
Sep 8, 2015 11:12 AM
rohnin
Sep 7, 2015 01:10 PM
