Collapsed vacuum hose + eractic idle please help
Old Apr 17, 2008 | 11:04 PM
heavychevy's Avatar
What is the F hose?
Old Apr 18, 2008 | 07:28 AM
Seal Grey Matte's Avatar
Seal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to behold
The rubber hose that both Diverter Valves plugs into (kinda looks like an F).
Old Apr 18, 2008 | 07:51 AM
heavychevy's Avatar
What about the one below the DV's, that is Y shape, has anyone found that one screwed up other than me?
Old Apr 10, 2020 | 05:40 AM
wkf94025's Avatar
wkf94025 is infamous around these parts
I am having same symptoms and fault codes on my new-to-me 2001 996TT as OP cited in post #1 some 12 years ago:
... my 2001 996 turbo regarding slow responsive throttle and eractic idle. (car will idle smooth then suddenly struggle almost stall and recover). When you slowly put in throttle (car stationary) the car feels sluggish at first then after a certain point in revs just fine.
Though in addition I am experiencing weak boost (0. 2 or 0.3 max bars). I have not looked at the collapsed hose that OP experienced, and have not yet performed boost leak test. But since symptoms and codes so similar to mine, I was curious what OP's resolution was?
First post here on 6speed. 20yr 996 NA owner, new to 996TT last month.
Old Apr 10, 2020 | 09:35 AM
'02996ttx50's Avatar
testing will reveal the leaks you probably have. a collapsed hose is massive and would result in the issues and absolute loss of boost as you describe and outlined in your other thread - while a minor leak ( like say a faulty #16 check valve ) would also cause issues of a lesser severity. but leaks are leaks - and you've probably got some.
996737fly
Jun 11, 2014 12:27 AM
Wishdiver
Apr 15, 2012 11:54 AM
H8T WP
Feb 28, 2012 02:43 PM
awdbiturbo1
Sep 6, 2011 12:42 PM
