High Pitched whine + Power Steering
Old Apr 9, 2008 | 09:12 AM
TXGold's Avatar
TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !
After driving for thirty minutes at highway speeds, I was coming to a stop to pull into a parking garage and I heard a high pitched whine for ~10-15 seconds. Is this a normal operation for the power steering pump? I don't remember hearing the pump except in the morning or when cold. Warranty runs out in a month, so I'm sure all kinds of **** is going to start falling off the car(like the left horn that quit today).
Old Apr 9, 2008 | 09:36 AM
996twin_sc's Avatar
996twin_sc is infamous around these parts
Does the sound go away when you depress the clutch?
Old Apr 9, 2008 | 09:41 AM
TXGold's Avatar
I guess I'll try that next time I have the chance. If it does, is that the Slave Cylinder going out?
Old Apr 9, 2008 | 10:53 AM
JoeyG's Avatar
JoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud of
Old Apr 9, 2008 | 11:18 AM
TXGold's Avatar
I just did the 30 seconds of 3-4K RPM revving and didn't hear any whining coming from the PS Reservoir, or anywhere else.
I'm hoping to hear that occasional brief whining from the PS Pump is normal. I am not used to hearing it after the car has been warmed up.
Old Apr 9, 2008 | 11:46 AM
how about you check the pentosin container near the AC compressor to see if you have enough fluid...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Apr 9, 2008 | 02:51 PM
MX RACER's Avatar
MX RACER is infamous around these parts
It sounds like this .... There is a TSB to fix this (#4897, 1/05). Pressure relief valve in the power steering reservoir. I had the same thing it was fixed under warranty.. Mine seemed to do it more when it was hot ( summer )....
George
Old Apr 9, 2008 | 04:38 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
I think I have the same problem as well..........what is the potential for this problem? What gives out? and worse case scenario?
Old Apr 9, 2008 | 05:39 PM
ard's Avatar
ard
Porsche Flambe.
The pentosin fluid is highly flammable, and when it hits hot exhaust, watch out!
Old Apr 9, 2008 | 05:47 PM
unvmy996's Avatar
yeah i remember ,some ones car caught on fire on here.
Old Apr 9, 2008 | 06:15 PM
Jesus's Avatar
Jesus is infamous around these parts
I have the same problem as we speak, took it to the dealer the Porsche tech heard it and rapidly told me it was the PS Reservoir, my 03 is CPO but unfortunately covers one of the two parts needed for the replacement, in conclusion the part that is not covered by the extended warranty costs $1,500 !!! ouch ! At least that's what I was told by the SAdvisor. I rev it to 3-4K and while the RPM's come down slowly it makes the noise for a few seconds just like you described.
Good luck,
Old Apr 9, 2008 | 07:54 PM
ard's Avatar
ard
Good luck,
Hopefully you are fighting this!
The CPO does NOT COVER JUST A LIST OF 'PARTS', legally it describes categories or parts and events that are warrantable failures. (They may have a list of parts they use internally, but at the end of the day, it is the FAILURE MODE AND PART that matters. In particular the CPO covers:
"Steering (incl. power steering and hose)"
http://www.porsche.com/usa/pre-owned...oved/warranty/
It is NOT possible for the warranty to cover a single failure, but only ONE part. Either two parts failed at once (never) or one failed and took out the other, or they are lying. If a warranted part failed, all the subsequent damage is also covered. if an unwarranted part failed, well then the initial AND all subsequent damage is NOT covered.
The real reason is that they figure you are gullible and will pay them the $1500. (Are you? ) Since PCNA will only reimburse them 3 hours for the job, at a rate way less than the hourly rate you pay. Heck, they may even double dip- submit for the cpo AND have you pay for work.
Also note that there is a TSB for this failure- it is a known failure.
This is a real crock...
A
Old Apr 9, 2008 | 09:12 PM
LiNks's Avatar
Originally Posted by ard
Porsche Flambe.
Enough said, we will be stopping by the dealer tomorrow, thank you very much!
Old Apr 9, 2008 | 11:25 PM
TXGold's Avatar
So if I did the 3-4K RPM for 30 sec check, am I most likely okay?
My PS fluid is just below the Warm line and its been sitting for an hour after a twenty minute drive.
Does the PS pump always make the same sound when it is working, and the problems described above lie with the timing of the sound?
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
Michael_s
Sep 11, 2015 08:03 PM
MurderedTurbo
Aug 28, 2015 09:06 AM
Zero911
Aug 24, 2015 06:51 PM
JMon
Aug 21, 2015 08:20 AM
