Softronic ECU Flash with FREE Diagnostic Software
Old Apr 28, 2008 | 05:19 PM
docdan's Avatar
docdan Is a GOD !docdan Is a GOD !docdan Is a GOD !docdan Is a GOD !docdan Is a GOD !docdan Is a GOD !docdan Is a GOD !docdan Is a GOD !docdan Is a GOD !docdan Is a GOD !docdan Is a GOD !
Originally Posted by vividracing
Yes all this can be requested. For example if down the road you decide to run straight pipes, put a email request in for a new MAP to turn the O2 off. This would not be a revision. Revision is only for MAJOR changes in fuel, turbos, engine (cams), etc.
Hi Dan,
I'm still on the fence on whether I should upgrade my ECU from the GIAC to the Softronic. I'm leaning towards taking the leap, but first I have a few more questions, if you don't mind.
1. It is my understanding that the Softronic Flash adjusts itself automatically(?) when I put in 100 octane fuel to optimize the engine for this higher octane. And I presume it will automatically adjust itself back when I put in 93 octane pump fuel. Just wanted to be clear on this.
2. If for some odd reason, it seemed like my car ran 'faster' with it's original GIAC flash, would I be able to revert back to this flash, or will it be destroyed forever?
Thank you,
Dan
Old Apr 28, 2008 | 05:37 PM
vividracing's Avatar
Softronic will give you more longevity as you modify your car because of their extensive map base and tuning capabilities. As you sit right now, just changing reflash, you may see a slight difference, but non huge effects like the first time you flashed it. Since Softronic pulls the last known file on your car, you could revert back to the GIAC one if you desired too. You are also correct about the fuel. The only difference would be if you were to use say leaded C16.
Old Apr 28, 2008 | 07:37 PM
Marine8541's Avatar
Marine8541 is infamous around these parts
All 7.8 DME's have adaptive thresholds and the the 997/987 7.8.40 is faster. Depending on how the software changes are made makes up on how adaptive or versatile a map is.
Originally Posted by docdan
Hi Dan,
Thank you,
Dan
Old Apr 28, 2008 | 09:08 PM
docdan's Avatar
Sounds good.....could you say that in layman's terms please?
Old Apr 28, 2008 | 09:13 PM
I have to tell Scott that sometimes too Basically yes to your question. The ECU is adaptive.
Old Apr 29, 2008 | 11:56 AM
muker's Avatar
muker is a jewel in the roughmuker is a jewel in the roughmuker is a jewel in the roughmuker is a jewel in the rough
Is there a big difference in performance for a stock set-up between softronic flash and upsolute flash? I read all the advantages you list but I am wondering if for someone doing just flash+exhaust if the upsolute route is a better value at $700. Let me know what you think
Old Apr 29, 2008 | 12:05 PM
To my knowledge, Upsolute is chip soldering, not reflashing for the 996TT. Softronic is an OBDII Flash. Softronic tunes the ACTUAL lambda and timing tables individually for the best file to adjust accordingly. They do not do Global Changes. So Softronic will adjust to basic bolt ons such as intake, exhaust, octane. Many other tunes have to be adjusted. The only time you need to re reflash your ECU is for changes in fuel (injectors), cams, turbo size. Softronic also has an extensive database of maps for turbo setups like the K24/18G, K16/16G, GT28, GT30, GT35 turbos, and more. Custom tuning is available based off their Durametric Data Logging. So you can upgrade and have your car tuned as you go further with your performance mods.
Old Apr 29, 2008 | 12:06 PM
Thanks for the order DocDan!
Old Apr 29, 2008 | 03:35 PM
pumalex's Avatar
pumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond repute
quick question, let say i buy the flash and i sell my car in a short time afterwards (i want to get an other color) can i use the flash on my new car?
Old Apr 29, 2008 | 06:10 PM
The flash is VIN specific. We can try to figure something out though if that situation arises.
Old Apr 30, 2008 | 06:31 PM
Last day for special. PM me or call if you want to order.
Old May 1, 2008 | 08:30 PM
Prche951's Avatar
Dan, thanks for helping me out. You're a class act.
Old May 2, 2008 | 09:02 AM
no problem. i try to do my best for people in times they need help.
the special is now back to $1995 with the free FLASH cable. If you are interested in getting this for your TT, X50, or GT2, PM me!
Old May 4, 2008 | 09:29 PM
cfi_luz's Avatar
cfi_luz is infamous around these parts
Great, so this has been extended? I wasn't able to act this month as we are bidding on a new home so I have to keep expenses in check until we have it secured but I'll definitely be acting soon.
Old May 4, 2008 | 09:36 PM
The price is $1995 and includes the standard Flash cable. The Durametric cable is an additional $250. Sorry the special ended May 1. If you are not making changes to your car constantly, you dont need the durametrics.
